Posted September 26, 200323 yr in time when money is abundant (thats right, i dont have money for wood) i will build a new box for my xxx. right now i dont like the way it sits in my car facing upward and you can barely see it because the box is so tall. so to remedy this i will have a more flat box with the sub inverted so there is no mounting depth and to give it more area and also to show off the sexyness of the sub and its entirety.alP.S. what should i tune it to, im thinking along the lines of 28, i want to show everyone a big sub isnt sloppy, maybe even lower.
November 10, 200322 yr I'm assuming it is the new 2003 models too huh? I would recommend about 30 or so also to get a little bit of both worlds.
November 12, 200322 yr anyweres between 28-35hz WILL be ok and still give you SQ....what size sub is it and what type of amp your going to put on it....if you need help with the box just holla at me and ill help you....good luckjamie
