That will be okay for music.
Two 1500s can draw up to 320 amps but you will seldom be calling for that much power on music.
2 amps strapped, with both batteries (for the sake of not typing it over and over... voltage drops from 14.3v, to 12.8 the entire test... lol
4 ohm strapped = 1900 watts @ 82% efficiency
2 ohm strapped = 3150 watts @ 72% efficiency
1 ohm strapped = 3740 watts @ 68% efficiency
.5 ohm strapped = 4425 watts @ 65% efficiency
.35 ohm strapped = 5415 watts @ 62% efficiency
amps would only tolerate a VERY short burp @ .35..
So those test were with single 1000ca everstart maxx, 1 Eagle Picher 12a5000, batteries and a stock 80 amp alt?
Edited by SEC
  • 3 weeks later...
at 1ohm, the efficiency is 68%.. would the efficiency of the amp remain at 68% throughout its POWER range? e.g. supposed i strap a pair of 1500Ds, but only use around 2500-3000Wrms from them..
would using less power yield a greater efficiency?
thanks
thanks
That is 1 ohm strapped - or 1/2 ohm per amp.
Efficiency will be roughly the same at lower power levels - although, likely marginally higher in the low 70s.
^thanks..
that Eagle Picher 12a5000 is one helluva battery!
what fuse rating will I used if I'm running strapped 1500s for music? 275a per amp is a lot
The internal fusing is 160-amps per amp, so you can match that for 2 ohm strapped (1 ohm per amp).
  • 1 month later...
at 12 volts.. what voltage are you getting on the output with the speakers disconnected ?? with a 45 hz tone .....
Should see ~38 volts or so if the crossovers aren't in the way.
  • 1 month later...
Consolidated high and regular voltage testing threads today.
  • 10 months later...
in the strapped amp test, was that .35 per amp for a nominal load of .70 or .35 nominal, if so that is crazy. .175 ohms per amp, ouch.
It was 0.35 nominal, or 0.175 per amp. I don't recommend doing that :)
Was this .175 per amp after rise say or started at .175
so wait... idk where my last thing went but can we do .5 ohm no problem?
  • 4 months later...
After all of my reading. I knew I had read most of the pile. But then Jacob pointed me this direction. Thanks. The Aveo and the Fit are in the same sub compact class.
No worries.
Soapbox
