Posted March 10, 20179 yr How important are 45s inside an enclosure? Also how do you measure a 45 and braceing?
March 10, 20179 yr It's debatable how necessary 45's are needed for daily use but all in all it doesn't hurt. As long as your 45's aren't gigantic they don't take up much space at all, if you're worried you can calculate it using you can use this website to calculate bracing you can also use this to calculate the brace volume http://www.hometheatershack.com/forums/enclosure-volume-calculator/
March 23, 20179 yr Author Thank you. To be honest I'm still kind of confused on calculating 45s into my total internal volume i tried searching but no luck.. probably only need 3 45s total this is my first box I have designed entirely myself just want to to be as close as possible
March 23, 20179 yr A 45 degree triangle has exactly half the area (and therefore volume) as a square of the same size. Square area is Length x Width (volume then multiply it all by Height)...to convert to a 45 triangle cut it in half.
March 23, 20179 yr 45s were a big thing not too long ago but lately I haven't seen to many enclosures built with them.
March 31, 20178 yr I havent seen an enclosure gain from 45's in years. Pointless and a waste of time imho. If your competing, i would test without and with,...... but, i have never seen a gain using them. Ever. Bracing, ... im a fan of. 45's, i wouldnt even put a second thought in them, if it was me.
