I have a Chevy extended cab full size I want to compete with again, I don’t want a wall or blowthru
should I do 4 12” or couple 15” or 18”?
one big sub or multiple subs?
i will be changing out my alt and adding batteries as needed
i use to have 3 JL 12W7 I’m a slot port box with one 1000 slash amp per sub in an s10 extended cab hitting 153.4
I don’t want a wall but want the biggest I can, has to be 12” down from ceiling and behind B pillar so I could do couple different options, any recommendations??
chevy full size extended cab
thank you
  • 1 month later...
Did you figure out how much space you had to work with?
I have not yet no, the truck I got broke down so I’m fixing it now, until then I’m using my 2013 Fusion, I want a system in that too, any suggestions?
 Can’t go wrong with anything in the SSA lineup. I own several and I’m very happy with them. Same goes for the evil mids and tweets. Phenomenal performance for the price point.
  • 5 weeks later...
:dancing:
  • 1 month later...
On 12/27/2018 at 10:56 PM, escottl92 said:
The area I have to work with is 58” long x 36” high x 33” wide
You have room to be loud !
Is that only for the box, or for batts and amps too ?
Room for box and I want the amp inside, batteries will go in bed. I’ve been getting a lot of advice but non the same, I want either 2 15” or 2 18”, ported box, I can do one big amp or 2 smaller ones. My dilemma is what kind??? I’m open to any help thanks
