Posted August 21, 20187 yr I have a Chevy extended cab full size I want to compete with again, I don’t want a wall or blowthru should I do 4 12” or couple 15” or 18”? one big sub or multiple subs? i will be changing out my alt and adding batteries as needed i use to have 3 JL 12W7 I’m a slot port box with one 1000 slash amp per sub in an s10 extended cab hitting 153.4
August 21, 20187 yr Author I don’t want a wall but want the biggest I can, has to be 12” down from ceiling and behind B pillar so I could do couple different options, any recommendations?? chevy full size extended cab thank you
August 22, 20187 yr You need to measure the exact box and space you have before shopping. Until then we can't help.
October 5, 20187 yr Author I have not yet no, the truck I got broke down so I’m fixing it now, until then I’m using my 2013 Fusion, I want a system in that too, any suggestions?
October 6, 20187 yr 6 hours ago, escottl92 said: I have not yet no, the truck I got broke down so I’m fixing it now, until then I’m using my 2013 Fusion, I want a system in that too, any suggestions? Can’t go wrong with anything in the SSA lineup. I own several and I’m very happy with them. Same goes for the evil mids and tweets. Phenomenal performance for the price point.
November 5, 20186 yr Admin On 10/5/2018 at 9:09 PM, j-roadtatts said: Can’t go wrong with anything in the SSA lineup. I own several and I’m very happy with them. Same goes for the evil mids and tweets. Phenomenal performance for the price point.
January 2, 20196 yr On 12/27/2018 at 10:56 PM, escottl92 said: The area I have to work with is 58” long x 36” high x 33” wide You have room to be loud ! Is that only for the box, or for batts and amps too ?
January 2, 20196 yr Author Room for box and I want the amp inside, batteries will go in bed. I’ve been getting a lot of advice but non the same, I want either 2 15” or 2 18”, ported box, I can do one big amp or 2 smaller ones. My dilemma is what kind??? I’m open to any help thanks
