Posted July 17, 20197 yr Do you still build/stock these? I've been debating on whether I want to do a A-pillar fiberglass install(would be my first time) or be lazy and find the easiest option such as something like those pods. I was considering installing them on the plastic mirror cover panels but they are tiny and not sure if they'd fit properly or support the tweeters well.
July 18, 20197 yr 16 hours ago, bigger_george said: Doesn't PVC flex with temperature? Not sure if that's ideal. If it's PVC pipe, you'll be fine until you get close to 250F.
July 19, 20197 yr 23 hours ago, bigger_george said: Doesn't PVC flex with temperature? Not sure if that's ideal. No problems that I've found.
