updates
resin on the fleece:
first time i used my circle jib, damn that's slick, i have to make 3 more of these:
top of the box with the tabs that will hold the bolts that'll hold the box to the rear deck:
  • Replies 50
  • Views 8.9k
Very ncie work Tom!
If it has resin icing sure!!!!
I like the build so far tom.
Teach Wade alot PLEASE.
J
Sweet. So I take you plan on using FG for the front of the woofer as well? I assume so since you're making speaker rings like that.
kind of, but not quite
the FG will be used to make a cover panel for my rear deck which will cover those rings
updates
all of the visible screw holes bondo-ed up:
all interior seams sealed with resin:
rings and subs ready to go:
stuff to do before the SD meet:
sand outside of the boxes
spray boxes with truckbed liner
cut holes in rear deck larger
mount boxes to rear deck
add polyfil
install subs and wire 'em up
replace tweets
Looking great tom!
updates
someone stole my backseat!:
one of the holes in the rear deck, not pretty but it'll work:
new tweeters:
smaller than I thought they'd be:
add polyfil
replace tweets
nice, dude.
I cut the same sort of hole in my rear deck. It's very tough to make them pretty- it's not like putting a circle jig on a router.
Looking forward to more progress pics.
  • 2 weeks later...
Looks great tom, you do good work.
  • 2 months later...
