Posted March 19, 200718 yr Hey, I'm not really sure where to post this comment so I figured this would be the best spot since it's pertaining to my fi gear.I am considering going to my first comp, trying to find somewhere within 4hours of Myrtle Beach SC and I think the closest place is roanoke rapids next month. I am not sure which class I will be in trying to find out before I go. I will be competing with my daily driven yukon, boxes come above the window line (where in a newer yukon they would not ) I have 2 18" btls, 3 batteries (might get a few more, depends on class) and 2 4kw amps.If any more info is needed please let me know, I'm just trying to make sure I don't drive half a day to get creamed because they consider my box a wall. I'm considering building a box that will go below the window line, but I'd probably have to lower my rear seats, which they are not at the moment-would this change my class? I have read the rules for db Drag, but I'm still not 100% sure.I think I'd have to be in street max 1-2, or Super Street 1-2 (NW?). I'm just not sure what the difference is.Thanks in advance.
March 19, 200718 yr If you box is under the front window line, you would be in NoWall, if you box goes over the window line you are in SS 1-2. In Street max you are only allowed 1 battery up front, and none in the rear.
March 19, 200718 yr Author If you box is under the front window line, you would be in NoWall, if you box goes over the window line you are in SS 1-2. In Street max you are only allowed 1 battery up front, and none in the rear.OK, thanks, so it'd be super street since it's over the window and I'll have 4 batteries. Thanks a lot. Edited March 19, 200718 yr by tejcurrent
March 19, 200718 yr Also look for comps in Augusta............there is usually a chunk of dBDrag there around april.J
