Posted March 25, 200718 yr Are they measured when the subs are new and stiff, or after they're broken in?
March 26, 200718 yr They are not completely broken in however they are not straight off of the assembly line. nG
March 26, 200718 yr I believe from another post (I think nick maybe) said the sub would 'settle into' the parameters. I would really wait for one of them to respond to get the most accurate info though.
March 26, 200718 yr They are broken in for the most part...for parameter aspects..However dont put all your cards on the parameters for a box design...if that is what you may be using them for.-Nick from daytona
March 26, 200718 yr Author No no.I'm taking Fi's official box recommendations over anything else.Just wondering(academically) why the TS parameters suggest significantly different tuning parameters.
March 26, 200718 yr No no.I'm taking Fi's official box recommendations over anything else.Just wondering(academically) why the TS parameters suggest significantly different tuning parameters.Because...Real World > winISDnG
March 26, 200718 yr well I tried to key in the specs in WinISD and either i had errors or it value turns out different. Is that me or its the program. Btw any other software which allows me to desings the enclosures.
March 26, 200718 yr You don't need to select a driver in winISD to design a box... all it does is influence the graph... which is completely inaccurate anway.http://www.caraudio.com/forum/showthread.php?t=215849nG
March 26, 200718 yr I've never had any luck w/ winisd, it always give me strange results. I used to have it on my old laptop before it crashed, never bothered putting it on this one-just waste of space imo.
March 26, 200718 yr I've never had any luck w/ winisd, it always give me strange results. I used to have it on my old laptop before it crashed, never bothered putting it on this one-just waste of space imo.If you know how to properly use it, it's quick, simple, and accurate. Only use it to determine port length, that's it. I still do all the calculations on paper, and check my port length in winISD. nG
March 27, 200718 yr WinISD is good to fine tune a box not for building ground up...Subs are so different these days....When in doubt i would highly suggest you go with whatever Fi recommends (or any speaker manufacturer recommendation).I am certain Scott nick and shawn know more about the subs "potential" than some universal program
March 27, 200718 yr I've never had any luck w/ winisd, it always give me strange results. I used to have it on my old laptop before it crashed, never bothered putting it on this one-just waste of space imo.If you know how to properly use it, it's quick, simple, and accurate. Only use it to determine port length, that's it. I still do all the calculations on paper, and check my port length in winISD. nGIt really isn't much good for much else, it just doesn't give dependable results imo. Like you said yourself, you do the stuff on paper for a reason (besides knowing how to do it ) Edited March 27, 200718 yr by tejcurrent
March 27, 200718 yr Author I've never had any luck w/ winisd, it always give me strange results. I used to have it on my old laptop before it crashed, never bothered putting it on this one-just waste of space imo.If you know how to properly use it, it's quick, simple, and accurate. Only use it to determine port length, that's it. I still do all the calculations on paper, and check my port length in winISD. nGIt really isn't much good for much else, it just doesn't give dependable results imo. Like you said yourself, you do the stuff on paper for a reason (besides knowing how to do it )But if it's all math, your answers will be repeatable with a computer program.
March 28, 200718 yr Author Either the math is wrong (and should be "fixed").Or, the TS's are inadequate, and should be updated.Which is the case?
March 28, 200718 yr I can give 3 other calculators and when you plug in the exact same T/S parameters you will get a different design and output on each one...Bassbox prowinISDeven online programs will all punch out different designshttp://www.klausaudio.com/shop/custom-encl...oofer-boxes.cfmhttp://www.subwoofertools.com/forum/ported-box.asphttp://www.bcae1.com/spboxnew2.htmhttp://www.reaudio.com/speaker_box/LPort_Box_Calc.htmlMy advice is PM scott nick or shawn and ask them to help you with the port length or whatever you are stuck with on your box design...they actually test the sub in ALL box dimensions and port lengths for ported and sealed...including all the different options.... trust me nobody knows a subs potential output BETTER then the manufacturer...Remember winISD is a Universal program it is not targeted to give you specifics for a specific design of a subwoofer... It is theoretically IMPOSSIBLE to make a program be able to cover all aspects of every subwoofer.. Furthermore Subwoofer developement has come a long way... XBL2 technology, cooling, copper coils, flatwind, can not be factored into the program but all have impacts on the T/S of the sub.... ngsm had the perfect exampleReal world testing by the manufacturer of the sub > universal subwoofer program
March 28, 200718 yr Thank you for saying it much better than I was able to- never should've dropped outta college..
March 28, 200718 yr Neither. The "optimal" targeting for the enclosure programs is based off of something far from optimal for car audio. It doesnt take into account transfer function of the vehicle... and therefore is best used only for getting port info... and not so much for an overall design.I think what might be happening is that we list subs impedance per coil and not wired in series as the specs are taken. Simply try for the D2 to list the DCR or RE as 2.8 (or double the single coil load) and it should come out fine. D1s should be 1.4 not .7 (as .7 is per coil and specs are measured with coils in series for the least error).Thanks,Scott
March 29, 200718 yr Author I'm not using Winisd. I have before, and didn't like it. I'm looking at all of these box designing tools, and wondering why they all give different recommendations based on the same input.Is the math behind ports, shady and imprecise? Or, is the math static and the measure of TS parameters shady and imprecise? Does anyone have an excel spreadsheet for port calc's? I'm better with excel than with pen and paper.
March 30, 200718 yr I'm not using Winisd. I have before, and didn't like it. I'm looking at all of these box designing tools, and wondering why they all give different recommendations based on the same input.Is the math behind ports, shady and imprecise? Or, is the math static and the measure of TS parameters shady and imprecise? Does anyone have an excel spreadsheet for port calc's? I'm better with excel than with pen and paper.The T/S parameters are measured. The port formula is an algebraic equation giving you a length... for a set NET VOLUME, TUNING, and PORT AREA. Neither are shady, or imprecise... unless YOU make a mistake in mathematical calculations. IGNORE the T/S parameters, they are... sorry to say... of no particular use to you. nG
March 30, 200718 yr The math isn't that hard and all you really need is a calculator that can handle weird powers like 10^-.7 blah blahOh and port design has nothing to do with a woofer, ports are based off of tuning a ratio of port area and length to box area. Edited March 30, 200718 yr by audio-neon
March 30, 200718 yr Author Simply put DopeyNot all Programs are created equalcan you link me to a good one?
April 1, 200718 yr Dopey here is what i doI will use all the links i posted and note down the differences between all of them....then average it out...Or i just use one (mainly subwoofertools)Also just FYISome programs DO NOT work in Liters or Cu CM they work in inchesso you need to convert some of the T/S that are in Liters and CMExampleThe subs list Vas in Liters and some programs want it converted to Cubic inches try use thishttp://www.mhsoft.nl/conv1.htmjust type in the liter box 58.7 (which is the Vas for a 12" SSD D2) and it will pop out all the numbers converted into the right measurement when you click into the box... This holds true for all programs so try to double check what measurement the program wants versus what measurement the site lists.... Edited April 1, 200718 yr by theabunai
April 5, 200718 yr Im not morally opposed to WinISD. It works fine for getting ports correct, but you have to know what you want in a response curve before hand. I often use lspCAD for design work. Its a little more complicated than WinISD, but it allows me to import FR graphs and really get a solid design going. But... your cars basic transfer function mucks up the nice response curves you see in the programs anyway (I can correct for this in lspCad, as Im sure you can in BB Pro).Our recommendations are based off of what we feel works and years of knowing what most customers like. My own personal tastes in systems seem to stray off the norm...WinISD is free, and feel free to use it for port work. That online box calc program works too... although it makes its own port suggestions based off of the entered Xmax and doesnt allow you to change it since we know better than it. Unless you are trying to get a very specific response curve in a car... simply do what you feel is best and what we/others recommend or have done and work with that. Over time you will learn what response curve you are looking for in a given application... and it is far from what many programs recommend.The programs work fine for many things, but higher power and pressure applications, things start to change. The ever increasing complexity/order of an enclosure all of this gets even worse. Its hard to model things in a static situation when all parts involved are very dynamic (but some programs are getting better at non linear modeling too).
