Posted March 28, 200719 yr Well i just got an absolute powerhouse of a sub .. an Ava 15 do you think itll take an kx1200.1? ne one with expierience wiht it?
March 28, 200719 yr don't know what the kx1200.1 does, but if it does what the name implies you'll be fine. I ran my ava15 off an orion1200d and they were quite happy together
March 29, 200719 yr i have run both a hifonics bx1500d and bx1000d on an ava.15. the 1500d was a little too much @1ohm if you are hard on it. the 1000d (which i am running now) seems to be a better match when running at high volume for an extended amount of time. iirc the kx1200.1 does around 1400 watts @1ohm. if you set the gains properly you shouldnt have any problems. i rec. about 3.5 cuft @ 30hz lmk if you have anymore questions.....
