April 19, 200718 yr Author the 18 has more cone area...Are you saying the 18" would be louder since it has more cone area
April 19, 200718 yr the 12's if they are going to see the same power.other than enclosure design differences,the 18 still has cone area advantage.Its the same series of woofer so excursion etc. is equal.Full power into the 18 vs. half power into each 12 so the only offset to me would be 18 sealed vs. 12s ported for the 12s to win this!
April 19, 200718 yr the 12's if they are going to see the same power.other than enclosure design differences,the 18 still has cone area advantage.Its the same series of woofer so excursion etc. is equal.Full power into the 18 vs. half power into each 12 so the only offset to me would be 18 sealed vs. 12s ported for the 12s to win this!he never said anything about them being ported or sealed
April 19, 200718 yr he didnt say anything about them seeing the same amount of power either so if each twelve gets say 1200 watts each (2400 total) and the 18 gets 1200 the twelves are gonna be louder they are seein twice the power
April 19, 200718 yr sd on the 12 is 481cm^2sd on the 18 is 1210cm^2That is a 248 cm^2 difference between 2 12s and 1 18. Theoretically giving the 18 the advantage if everything else is the same. If you give the 1 18 1500 watts, or the 2 12s 3000 watts, the 12s could have the advantage. Its a matter of your setup. If you have the room for a good box for an 18, I'd go with 2 15" BLs. just my opinion.
April 19, 200718 yr Obviously you didnt understand my post because I was agreeing w/acid burn. I was using variables for examples,I didnt say he was using ported or sealed or power to each etc etc, they were just offsets that affect the outcome.Basicly apples to apples 18 ftw over 2 12s.Now bring enclosures and power variations into it like tejcurrent said the install will decide the win.
April 20, 200718 yr i did understand you post all i was saying is that just because the 18 has more surface area doesnt mean that its going to be louder. some one already stated that if they were run of the same power then yes the 18, i was just stating that if each sub was run of maximum power then the 12's would be louder
April 20, 200718 yr i just changed out 1 18 for 2 12s. still using the same amp, the 2 12s are "louder" because they are tuned at 32 vs 30. but that is just my situation. if you really want louder, get the damn BTL.
