Posted April 20, 200718 yr I really need to know what would be the best amp that can power 2 12" BL series subs.
April 20, 200718 yr Try look at this threadhttp://www.soundsolutionsaudio.com/forum/i...?showtopic=7834 Edited April 20, 200718 yr by theabunai
April 20, 200718 yr You can't go wrong with a Kicker KX/ZX2500.1.. Edited April 20, 200718 yr by PsychoTheRapist
April 21, 200718 yr 1 amp for both subs:Kicker 2500rockford 3000.1, rockford 4000.1cactus sounds 4kMemphis 4kCould put 1 hifonics bxi2006d, or 1606 per subI'm sure there's others, but depending on options I would give each sub 1500wrms. If you get a bigger amp you'll always have overhead, and room for expantion. Edited April 21, 200718 yr by tejcurrent
April 21, 200718 yr 1 amp for both subs:Kicker 2500rockford 3000.1, rockford 4000.1cactus sounds 4kMemphis 4kCould put 1 hifonics bxi2006d, or 1606 per subI'm sure there's others, but depending on options I would give each sub 1500wrms. If you get a bigger amp you'll always have overhead, and room for expantion.Pair of Sundown SAZ-1500D's...Even the pair of SAE-1000D's would work...$450 for the pair on preorder...
