Posted April 29, 200719 yr Which amp for great sound quality and build, but the MOST important is efficiency (stock 90amp alt. but doing the big 3 soon) .thankz in advance.JBL GTO1201.1 IIApline MRD-M1005INFINITY 1211AKenwood KAC-X1ROrion HCCA-D2400PHOENIX GOLD RSD1SoundStream PCA1500D 200.1 Edited April 29, 200719 yr by solidcrowd
April 29, 200719 yr Author Why not get an SSD and run less power?I thought about that, i was thinking about getting the ssd with copper coils and bp power. But i have a few questions i need to get cleared up, for an example say i have a true 1000watts going into the q and a true 1000watts going into the ssd with copper coils and bp power which one would be louder? and what one would sound better? Also, would the q take more watts to get moving..causing a decrease from getting loud? where the ssd isn't needing as much watts to get moving therefore more output?
April 29, 200719 yr which one would be louder?Totally dependent on your install.and what one would sound better?Dependent on your install, your taste in music and how picky you are.I don't think you'd have a problem with an amp in the 800-1kW range and a small 50x2 amp for your front stage, as long as you're smart about things...
April 30, 200719 yr Author so should i get the fiq or the fissd with copper coil and bp power? i was thinking i might as well get the q beucase it can handle more if i decide to upgrade, has a more xmax, and the price is so close y not.
April 30, 200719 yr Author I kno thats the problem lol why are they so similar to eachother, ooo00 and i know its all install dependent but which setup will be the loudest n have great sound quality out of these choices:Basically im looking for a great realiable amp thats super efficient with the most true watts*90 amp alt, 0 gauge amp wiring kit*Box probably going to be 2.2 @ 33hz (its in a 99 saturn sl2)Fi Q or F i SSD copper coils, BP powerand with what amp? JBL GTO1201.1 II 1114 X 1 2ohm 115 amp 3X40fusesApline MRD-M1005 1000 X 1 2ohm Heard only draws 90 ampsINFINITY 1211A 1300 X 1 2ohmKenwood KAC-X1R 1200 X 1 2ohm PHOENIX GOLD RSD 1200 x 1 2ohmMy very first choice was the fi q and the apline, n now im thinking the phoenix goldPlease pick what combo you think would fit my application, i want to get this project done
April 30, 200719 yr They all look like more then capable amps.I would choose the amp with the best features on it like subsonic filters, crossover, connections, and others.
