Is it possible to hook up the minilith using only the sub out RCA's. I tried this once real quick, but did not get any signal. Should I try just splitting the left and right out puts on the RCA to get 4 inputs to the amp. HELP!
IF you can't figure a solution, email Stephen directly.
From the man himself...
Sure just Y adapt so all four inputs receive signal. Each RCA NOT receiving signal drops the gain of Minilith by 6dB
Thought I would post this since I'm sure someone else may run into this situation. :fing34:
