Posted May 3, 200719 yr just as stated in the title.....ive always been a big fan of fosgate but i saw a well known guy running 4 btl 18's hittin in the high 150's and the btls are half the price of the T2's....any input would be much appreciated
May 3, 200719 yr the t2 suck. get the btl. and i've not even played with the btl. but i have played with the t2, and while it can throw down, there are lots better out there for far less money and better support. the btl being one of them. hell, you can grab a pair of mojos for the price of one t2. they handle the same power and have better support as well. wheeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeee
May 3, 200719 yr Author yes my needs are SPL B) im limited in my hatch space to around 8 cubes should i get one 18 dual 1 ohm coils running off 2 T10001bd's (have one already) or 2 15's with dual 2 ohm coils wired to 1 ohm on 1 T1K per sub?
May 3, 200719 yr Admin 2 15's will have cone advantage, but to get the most out of the BTL your going to need more then 1000 watts. You could almost go with a pair of Q 15s or BL 15.
May 4, 200719 yr Denim is rightBL with full cooling and have them design it for SPL instead of daily....Trust me it will WANG WANG WANG
May 4, 200719 yr Author ok so they can handle some power......how about a T4k on 2 BTL 15's ....and can you get them with dual 4 ohm coils.....that way i could wire it paralell str8 to 1 ohm to get the full 4k
May 4, 200719 yr 2 dual 1's will get you to a 1 ohm final load. wire the vc's on each sub in series then wire the subs in parralel.
