Posted May 6, 200719 yr can you guess what im going to put in the old F-150@ least till my new subs come in ...
May 6, 200719 yr Author i take it the flush bit worked out okay!?!?looks like it'll go boom like so...ok is an understatement that thing rocks...all i did was line up 2 corners & Bammmmmmmmmmmmm done in 30.min
May 7, 200719 yr Author boxx specs:external dimentions:H:36"W:42"D:23.25"face plate 3" thickport: 34.5"x7.75"x 5.5"Lv
May 7, 200719 yr Author i can't take all the credit...DjMan built the Boxx, & im finnishing it out by adding the 2nd face plate, some angles & short walls in the boxx, & Fiberglassing the inside... to help the subs load better
May 15, 200718 yr Author Gotts ta tweek it a lil & add FG and short walls ect ect ect i took out the brace and am going to use the devider walls as the bracing and maybe a few rods of All-thread...
