Posted May 6, 200719 yr whats the best box to use ported or sealed? , how much of a difference is there?, what should it be tuned to? and what size? thanks also any one have a video of a mj-18 in action thanks again
May 6, 200719 yr There's a couple of MJ-18 videos here. Click on "Mach 5" on the left side.http://www.realmofexcursion.com/videos.html
May 7, 200719 yr Admin For sealed I prefer 3.0 or a tiny bit larger, as for ported, minimum of 4.5 cubes.
May 7, 200719 yr Author For sealed I prefer 3.0 or a tiny bit larger, as for ported, minimum of 4.5 cubes.thanks more info on different boxs any one
May 8, 200719 yr I had them in 3.25cf sealed a piece, and I recommend going larger.I'd say 4cf a piece.As for ported, definetely minimum 4.5cf. For car use, as big as possible and tune between 30-35hz. You won't be able to go too big in a car For home use, 6cf tuned to 30hz should do well on music, and something big like 10cf @ 18hz for HT usage should rock your foundation.
May 16, 200718 yr How does box size correlate with box size? I am thinking two mf-18s, but I only have 1,000 watts. Perhaps 1 18 would be better as I can better power and port it.What is the reccomended port area for these subs? I assume my two aeroports won't be enough.
May 16, 200718 yr HI Flip, what size ports do you have?4".I would still rather go with the 8s though. It's either this or the 8s, depending on what you can do. I will be using an alpine pdx 1.1000 so I have 1,000 from 2-4. Edited May 16, 200718 yr by Flipx99
May 16, 200718 yr Admin Hey flip, I would not worry about the power, I tested my MJ on 400 watts and it did just fine. They dont need a ton of power to get going or sound great. But they can take more then ratted, if you are smart with the gains.
