Posted May 19, 200718 yr Will 2-18'' BTL's be happy with 2000 watts per sub? And will they play with 2000 watts each or do I need to put 4000 watts per sub? Need to smoke 2-13" w7's. Can 2000 watts per sub do it???
May 19, 200718 yr Will 2-18'' BTL's be happy with 2000 watts per sub? And will they play with 2000 watts each or do I need to put 4000 watts per sub? Need to smoke 2-13" w7's. Can 2000 watts per sub do it???With 2k watts, though it's all install dependent, you should have no trouble. If you have the cash for it though, I'd get 4k a piece-The difference is worth it to me. But if you don't want to pay the enormous difference, 2k a piece will get the job done. Edited May 19, 200718 yr by tejcurrent
May 19, 200718 yr I don't see why two 18'' btls would'nt beat out the w7s.You would already have a cone area advantage.Install will be the deciding factor.Oh and make sure it's got good clean power!
May 19, 200718 yr They'll definately be louder that 2 W7's.I hope you aren't looking for them to sound better though.
