Posted May 22, 200718 yr ok this is what's up I have an mmats d3500.5 I can buy 2 more or 3 massive p3000.1, already got 3 kenetik 2400's to add to the 2 1800's under the hood. I plan on putting the 3 15's in a fiberglass wall like the old JL audio 3 10 set up approx. 7-8 cuft per sub, so what amps would you guys suggest. Oh getting 3 massive's or 2 more mmats would be about $100 doller dif.
May 22, 200718 yr i vote MMats. only becuz i heard the massives dont do 3K someone said about 2300 actual clean power. thats just my opinion. i see alot of ppl running mmats, never heard anything neg about them. also, do u have 3 15's or 3 18's? title says 18 but in ur post u say 15's. with 7-8 cubes per sub i assume u have 18's.
May 22, 200718 yr Author i vote MMats. only becuz i heard the massives dont do 3K someone said about 2300 actual clean power. thats just my opinion. i see alot of ppl running mmats, never heard anything neg about them. also, do u have 3 15's or 3 18's? title says 18 but in ur post u say 15's. with 7-8 cubes per sub i assume u have 18's.Yea sorry typeooo 3 18 btls fully loaded......... wow 2300 ive been trying to find some info on the massive p3000.1 but it feels like not very many people use massive that could be why humm
May 23, 200718 yr http://ampguts.realmofexcursion.com/Massive_Audio_P3000.1/1 x 1800W @ 4 ohms (< 1% THD)1 x 2680W @ 2 ohms (< 1% THD)Max: 1 x 3000W @ 2 ohms (14.4V)Fuse: External 200ALenght: 34.7in (88 cm)Don't know how the rms is less than 400 less than the max...You can see it isn't putting out 3krmsThat ampguts site is normally pretty good, I'd search there a little.If you already have 1 3500.1 I'd just get 2 more imo. Good luck.
May 24, 200718 yr Bottom line is for the price the Massive P3000.1 can be had for it is almost untouchable for power output to price ratio. For the price of the 1 Mmatts 3500.05 he can almost by two to the Massive P3000.1Also where is the 2300 watts number coming from. The numbers for the P3000.1 is always around 2600 - 2750 @ 2 ohms @ 14 volts as stated above, and for around 500 bux its hard to beat.I have had more problems with the new Mmatts sub amps then I have had with the Massive sub amps. Now the Stereo amps is a total different story!Just a little food for tought!
May 24, 200718 yr there was a discussion about massive ampsherehttp://www.soundsolutionsaudio.com/forum/i...?showtopic=7004
May 24, 200718 yr like i said, someone told me that they did about 2300 of actual clean power. didnt say i tested it or anything. i was interested in buying a massive 3000 because it was so cheap on ebay, but someone on here suggested i didnt because they didnt put out the power they are supposed to. just trying to help this guy out.
