Posted May 27, 200718 yr Admin Here are the T/S Parameters we promised: ICON 10" SUBWOOFER DUAL 2 OHM COILS Re 1.5 per coil (specs measure in series 3.0) Fs 30.7 Qms 5.60 Qes .41 Qts .38 Mms 190 g Sd 310 cm^2 Vas 19.1 l Bl 16.4 Spl 83.1 1W/1m Xmax 20.5mm Wattage: 1000RMS Displacement: 0.12cuft ----------------------------- ICON 12" SUBWOOFER DUAL 2 OHM COILS Re 1.5 per coil (specs measure in series 3.0) Fs 29.9 Qms 5.87 Qes .45 Qts .42 Mms 212 g Sd 480 cm^2 Vas 43.7 l Bl 16.4 Spl 86.0 1W/1m Xmax 20.5mm Wattage: 1000RMS Displacement: 0.16cuft ---------------------------- ICON 15" SUBWOOFER DUAL 2 OHM COILS Re 1.5 per coil (specs measure in series 3.0) Fs 26.4 Qms 6.01 Qes .48 Qts .45 Mms 262 Sd 810 cm^2 Vas 127.8 l Bl 16.4 Spl 88.7 1W/1m Xmax 20.5mm Wattage: 1000RMS Displacement: 0.19cuft
May 28, 200718 yr Admin Again, that 15" looks yummy. Qtc .707 looks to be around 3.0 to 3.25 cubic feet.man are they! just installed two of them (check build logs, click here), wow they sound great.
May 28, 200718 yr What I want to know is what's the mounting depth for the 10" and 12" Icons. My Massive Audio P1000.1 amp does 880 Watts @ 1 ohm, so the power is already taken care of.
May 31, 200718 yr 10"=6.5" mounting depth, 12"=7.0" mounthing depthI just want to verify. On the website, it says the 10"=6" mounting depth, and 12"=6.5" mounting depth.7" is to much for my app., so I was thinking the 10" sub, but now I can do the 12" if the mounting depth on the site is acurate.Thanks.BTW: Who do I ask to get a shipping quote to get one of those to Honolulu, HI 96819? Edited May 31, 200718 yr by king alpha
May 31, 200718 yr Admin 10"=6.5" mounting depth, 12"=7.0" mounthing depthI just want to verify. On the website, it says the 10"=6" mounting depth, and 12"=6.5" mounting depth.7" is to much for my app., so I was thinking the 10" sub, but now I can do the 12" if the mounting depth on the site is acurate.Thanks.BTW: Who do I ask to get a shipping quote to get one of those to Honolulu, HI 96819?so sorry, the site info is correctpic deff could be clearer, but I have lighting issues, anyways, hope this helps
March 25, 200818 yr Admin went ahead and changed the RMS of the ICON to 1000wRMS, since we all will agree that they won't even break a sweat at that wattage.
March 25, 200818 yr went ahead and changed the RMS of the ICON to 1000wRMS, since we all will agree that they won't even break a sweat at that wattage. i was worried at first about the rms because im going with 2 kicker 2500.1 and putting 1250 into each sounded a bit much..but after reading more i think i'll be ok with 1250..
March 26, 200818 yr Admin went ahead and changed the RMS of the ICON to 1000wRMS, since we all will agree that they won't even break a sweat at that wattage. i was worried at first about the rms because im going with 2 kicker 2500.1 and putting 1250 into each sounded a bit much..but after reading more i think i'll be ok with 1250..Should be just fine with that.
