Posted May 28, 200719 yr I've got 2 dd 3515's dual 2 ohm, right now i've got 2 sundown audio 1500d's strapped @ 2ohms. I'm wanting to get 2 more 1500d's. my question is would the amps handle bein strapped @ 1 ohm daily? i wanted to ask first before i reconed the subs to dual 1 ohm...thanks in advance.
May 28, 200719 yr They will handle it just fine with the electrical listed in your sig -- but won't be covered under warranty if purchased after March 31st.
May 28, 200719 yr They will handle it just fine with the electrical listed in your sig -- but won't be covered under warranty if purchased after March 31st.What would you guess the output would be ?
May 29, 200719 yr They will handle it just fine with the electrical listed in your sig -- but won't be covered under warranty if purchased after March 31st.What would you guess the output would be ?Scott,Full power testing is in the sticky post:http://www.soundsolutionsaudio.com/forum/i...?showtopic=7116Dopey posted the most relevant figure for you.
