  • Replies 859
  • Views 180.1k
thanks :D Heres a little vid i made tonite..
its not all that exciting but it shows a little of how the levelPro system works.....im so happy i finally got it dialed in! Tomorrow i put the Nitrogen bottle and regulator in and then im done with the air system!
seriously steve, if it werent for your crazy youtube videos... i never would have even knew about Fi. thank god you've spread the love.
todays work.....i can finally almost say im done laying under the truck!
CarPuter came in today!! Sick as hell! The 10.2" touchscreen monitor will be molded in the dash soon :)
A little modification to the factory fittings...
Nitrogen bottle time!
Now time to tap into the system with the nitrogen bottle. A 3 way T will do it.
X marks the spot :) i need a hole big enough for 1 air line and 8 4ga wires to pass thru
4ga Speaker wire.......probably overkill for mids and highs but it is a long run from the rear to the front and this amp takes 4ga wire on all the terminals so why not
I had no place to clamp the wires down so i glued them together and then glued them to the box. This is superglue "jel". Its very thick CA glue.......
Started the dash early this morning...this is the 10.2 touchscreen for the carputer...
Edited by meade916
thanks! :)
Ok i tore the center console a new A-hole to get the carputer in......its DEEP inside but still somewhat accessable. I dont have any pics since im not done but i DID fire it up.......man its so sick i want to puke right now :D
three questions
1) where are the climate controls going
2) is the carputer close enough to load a CD still?
3) running a USB line out for ipod or similar hookups?
added some 2x3's and due to the way the box is designed i was only able to get the small 1 1/8" batten on the top and bottom. It works great though because when building a box inside of a car you need to screw from the inside out.......they will work perfect.
I been rackin my brain on this...how do you screw from the inside out? I'm walling my ride, almost all of the rear will be enclosure, with room in back for amps.
Fixed!!!!!!
Haha...must be trying to put out Mac...because it's on fire. I know, lame, but one photochop deserves another. thmbup
Ironically enough, that's how I feel about the Colts---JOKES!!!!
three questions
1)"hvac will go below in the console by the alpine i think"
2) & 3)i believe he is using a alpine headunit for that
