bottom glassed in as well.........i would say its pretty solid now :)
This is how i am turning 4ga mids and high wire into speaker wire for the doors (i know its not necessary but its a long run to the back by the amps and it looks cleaner back there then 50 16ga speaker wires jammed into the T15k terminals )
a couple shots of the door again to end the evenings pics :)
Edited by meade916
  • Replies 859
  • Views 179.7k
thanks!
ok todays update:
driver door in! I didnt put the speakers in yet.....i have to deaden the doors and then im ready to start hooking up wires!
Steve, keep up the good work. This is one of the largest fabrications most people have seen.
I'll admit its the largest I've seen. And the nicest install I've seen! Keep it up man! Amazing work!!
worked on the driver door today.......everything is X2 in this truck, always gotta be a right and a left side to everything and since its so much damn work, i feel i can post pics of the other side, even though its exactly like the other side :D
i also managed to get the wiring harness on the panel. Wires cut to length, tweeter wires soldered and heat shrunk. Mid wires go directly into the speaker terminals so no need to solder. Anyway the back of the panel isnt as clean as the front.......its all business back there LOL.
a close up to show the texture of the material.
Now can you see the beauty in the Molex Plugs :D Soon, i will plug it in and call it done......hassle free :)
just waiting on the armrests and window button housing.....being dyed to match the graphite grey inserts. Probably next week when i get back from Florida
you're in Florida? nice...not with the tahoe I presume...
  • 2 weeks later...
OK i spent some time during the week running crossover wires from the distribution blocks. Today, i got the armrests back from being dyed to match the suede. I layed 2 layers of Hushmat before i got started. The Passenger door, i am happy to say, is 100% done :D Here is just some of the weeks "labor".
OH ya, did i mention the seats are out for Leather and Suede? This is the last time you will see them tan. Slowly but surely all the tan and brown inside the hoopty will be gone :D
that is only HALF of the wiring, from the distribution to the inputs. I still have all the outputs to wire up....
time for some Hush Mat
Ok i used foam inserts to keep the 10's and 6.5's from mixing......the 6.5 foam pads were a pain in the ass and were not lettin me sink the speakers in as deep as i wanted so i took them out. The 10" pod is still there and i think thats all ill really need anyway...
Looks great. What about the center counsel and dash? Are they going to be grey too?
Ok it looks like the same thing but just like everything else, i MUST post pics of both sides.....so much work i just cant NOT show it :D
DRIVER AND PASSENGER DOOR PANELS DONE! :D :D Still gotta hook the wires up to the xovers. That will be this weekend.
Remember, disregard any Tan or Brown in the vehicle......the interior is gettin flipped and will match the panels...
Sick sick stuff bro. I appreciate you sharing your progress. It motivates all of us. :D
what kind of numbers you think you will get in the end with this caddy?
he has already hit a 160 With no tuning at all. I would think it would stay in the 160's. :-) Z
yea so when he finishes i believe it will be close to higher 160s
i dont know....i dont care. I touched a '60 and added a ton of mids/highs to go with it.....im happy with it the way it is ;)
easier said then done.....1db is major at this level. I just want it to sound killer as a package (mids highs etc), look good, and with the bonus that it can do that 160 if need be.
this is not a db-dragster......its 2.5-3db louder then my tahoe and the owner (chicken) wont even sit in that so i think he will be happy :D
yea i get what your saying, im sure the mids and highs will sound great in that thing, it looks like your almost done with it...
does he plan on painting the body? or leaving the original finish on?
just now clockin out for the evening......all the mids/highs are OFFICIALLY HOOKED UP!!! They sound INCREDIBLE!!! Vids tomorrow for sure!!
if you want to know how much power i am using total, here it is.
Mids/tweets hooked up @ .67 ohms. my guess is that is around 3,000 per channel. Im using 2 channels for those. So 6,000 watts.
Midbass is hooked up @ 1 ohm. That is 2000 watts per channel. So 4,000 watts.
subs are hooked up @ .5 ohms per channel...That is full power 3750 per channel.....so 15,000 watts.
totals: 10,000 on mids/highs 15,000 on subs.
do i have enough mids and highs to handle 10k, probably not.........but ive got so much headroom its crazy and these things SCREAM!!! Sounds clean as a motha#$%cka too!! Dont forget not only are these the biggest car amps out there, according to the "powercube" results, this is also one of the cleanest amps out there too :)
wiring madness part 2 :D
