nahhh the peice butts up against the body but it isnt attached. Its attached to the box...when the rubber trim goes back in place it should make a nice "break" in between the two pieces.
Edited by meade916
  • Replies 859
  • Views 186.1k
Good stuff Meade. Luv'in it mang.
You guys have alotta fun over there @Meades workshop.
Glad to see the Civic causing havoc again.
You da man.
went and got some steel.....some angle, flat and 1" tube.....time to make the battery tray and come up with something to hold T15K #2 in place.
this will start to make sense once i show you guys what the bracket for the T15K looks like. This is just the beginning of the structure i am going to fab up to hold the amp in its spot. Oh, the new welder is working LOVELY :D
I can't wait to see the numbers.
That amp is sweet. You can always expect a great build log from you Steve. Keep it up and can't wait to see the finished product.
One of the best build logs i ever seen.... it might be better then the tahoe build log steve LOL
I wonder what this bracket holds............. :D
amazing!!!!!
Today was bus bar day. I picked up some 1/4" aluminum yesterday and some Stainless Steel bolts.....hooked it up proper. Also primered and painted the amp rack black with a "hammered" finish. Im pretty happy with how it all came out.
It was scrap aluminum so you know it was dirty.....i took some 100grit then 260 and cleaned it up nice. It dont need a mirror polish, brushed is fine for its purpose. Plus it will never be seen unless you take the system apart :D
Ya, i know you like the how i did these fuses :D I just messed with them till i got them just right and they work GREAT!
A little Rockford Fosgate 2/0 should do this project up proper :D
As bad as i wanted to toss these on the ground and bust out the hammer......and flatten these bitches out, i decided to stick with solderin them. Gotta do it proper or dont do it at all :D 16 of them took some time but its worth it in the end. Thats just the begining of the soldering ill be doing in this truck.
you mean with THOSE amps? :D the second T15k is almost done being built ;)
Nice work on the battery bus bars. This is a really long build.
Thats the same metal that I used to build a plaform for my speakers in my van. Very nice to work with. Did you burn through the metal by any chance.
No shit?!
Dude, it was nuts before...
If i make it out west this summer i've GOT to hear it :) I had no idea you were doing 2 of the amps!
