Posted June 9, 200719 yr Im getting an Optima yellow top on sunday for a good deal.I also hear that the batcaps are magnificient also and out of sight.My question is should I get 2 optimas or get one optima and a couple of batcap 800's.I dont know how many batcap 800's im getting because they are so small.
June 9, 200719 yr Author class d amps need 1000 amps apiece to work properly, U really think to yellow tops will do it.
June 9, 200719 yr Author However u can get the most cca's thats all that matters, lol yea true that. I think im gonna get 1 yellow top and alot of batcap 800's.Or 2 all lead batteries, If I cook them really good like my homeboy did.They added up 2 a 26.7 battery charge.WOOOOOOOOOOOO In ya face. Edited June 9, 200719 yr by Gorilla Pimpin
June 9, 200719 yr i dont know, i got two batts a kinetik and an oddysey and i believe thats like 2400+1600=4000cca'stwo batts, lolplus a regular battery just because i didnt want to take it out.
June 9, 200719 yr Author I havent got that far but i tell u what I will be really soooon.Whats your voltage on them.
June 9, 200719 yr still a 12v system.i got a 250a alt as well, but i think i might need two more batts for my next setup.
June 9, 200719 yr class d amps need 1000 amps apiece to work properly, U really think to yellow tops will do it.You have 2 10,000 watt amps ?http://www.soundsolutionsaudio.com/forum/i...?showtopic=1118here is an excerpt"A typical Class D amplifier is about 75% efficient at full output. A typical Class A/B amplifier is about 60% efficient at full output. Essentially, divide the power output at full capacity by the efficiency, then divide by the test voltage. For example, an amplifier is 75% efficient @ full capacity (1000 RMS with 14.4 volts). This means that current draw will be 92.6 amperes with a sine wave at full capacity and, obviously, less current draw at less than full capacity."now that is a 1K watt amp at 14. volts and it only draws 92 ampsif your class D amps draws 1,000 amps that means it's essentially a 10,000 watts a piece from what i gathered...what kind of amps?I have 2 merlin md.1d 1K watts class "d" amps1 soundstream rubicon 502 100 watts per channel class "a/b" ampAll on one yellow top in the back stock batt up front stock alt and big 3 ...My volatge is steady at 13.7 volts and when slamming hard and rarely drops below 13V with the car on.... Edited June 9, 200719 yr by theabunai
June 10, 200719 yr ^ I wish somewhere around me sold kinetic. Might get 2 2500s offline if I could find a good price shipped, but I know my voltage problem is really alternator based (200a alt); no one near me will machine a bracket to fit a 2nd alt, and I'm considering just looking into 2 300a alts offline. I have 3 optima yellows, and a starter I'm considering throwing in there. Great for demo w/ the car off though. Within a month or two I'll have ~ 16000watts though, and I know my electrical system is sub-par for that. Need to get to work on that. Edited June 10, 200719 yr by tejcurrent
June 13, 200719 yr a member of my other forum was at deka the other day and found out that carquest batteries are made by deka and identical in every way but price. someone else said the group 31 agm was $129i wasn't sure if it was ok to likn to the other forum or not if its cool i will add the link
June 14, 200719 yr http://www.splbassx.com/forums/index.php?showtopic=9928http://www.carquest.com/common/downloads/p...eriesCQ_NGT.pdf
