Posted June 13, 200718 yr The web site FiCarAudiodoes not list Le (or alternatively Ls and Lp), the inductance parameters.Anyone know the values for the Q15 and the Q18?TIA =>><<=robobob
June 15, 200718 yr Author Wouldn't they be the same if the motor and coil is the same?Most likely. The question is: what is the Le or Lp and Ls parameters for the Q15 and Q18? Looking for a reasonably low inductance value for a good match to mid woofers.Thx
June 15, 200718 yr Off the top of my head I dont remember... Ill have to run one again to see. Its not low by any means, but they play well up into the 80s before Le takes over. Plenty good for a sub. When I get back into town Ill measure one and post it here.Thanks,Scott
July 4, 200718 yr Author Off the top of my head I dont remember... Ill have to run one again to see. Its not low by any means, but they play well up into the 80s before Le takes over. Plenty good for a sub. When I get back into town Ill measure one and post it here.Thanks,ScottHi Scott:I know that you are busy until after July 8th. When you have a chance after that to measure the Le (or Lp and Ls) for both the Q15 and the Q18 drivers, I would greatly appreciate it!Thx,=>><<=robobob
