Posted July 9, 200718 yr just wondering if i could beef up a paper cone with some resin on my ten's? can someone tell me how they did it? front or back?
July 9, 200718 yr What does this have to do with Sundown?And, sure, you can add some, but resin has no strength adding properties. Will also increase the mms completely changing the speaker response.
July 9, 200718 yr Dammar treatment for full range drivers is relatively common on the older ones, but that's not really related to what you're talking about.
July 9, 200718 yr look into doing a custom cone there are companys out there that make custom cones out of different material for ya and there not to bad priced.
July 9, 200718 yr DD offers the new composite cones, try one of those Should hold up to the pressure better than the regular paper.
July 9, 200718 yr Author DD offers the new composite cones, try one of those Should hold up to the pressure better than the regular paper.$262 for a composite cone . that is a little out of my range right now.sundown help make this happen! that's what it has to do with it neonrider
