Posted July 10, 200718 yr I'm keeping my 18", and starting on another box for it this weekend. My max dementions are 17" tall-38"wide-25" deep. That gives me just over 7.5cubes to play with. I'm going ported, and I was just trying to figure out what would be best; flaired or slotted?
July 13, 200718 yr Admin I vote slot port, big sub needs big air, and you want big output, so the less restriction on that air the better.
July 13, 200718 yr Assuming it is for a daily app, 2 6" ports is 56.5sqin which should be fine. For me I'd go with whatever is easier/fits your space better.
July 13, 200718 yr Author Thx for the responce guys. I have the space to go with either one (flaired or slotted), but I can get more sq" with a slot port. I wasn't to sure if "more is better"?
July 13, 200718 yr Most people would be fine with the two 6's...of course I am the guy who is running a 21sqin port for an Rli8 which equates to larger than those 6's per cone size.
July 13, 200718 yr Author Hmmmm............I can do a slot port with 70sq", and still maitain 6.7cubes.
July 13, 200718 yr Author I should probably add that i'll be useing an orion 2500d. So the single 18" will be getting around 1600-1800rms.
