Posted May 20, 200421 yr Sure, Adire has finally released them...The Adire Koda SubwooferRight now they are IN STOCK. That's right, a fresh new idea, introduced and released with no pre-order!!!Something awesome this way comes Fs 28 Hz Qms 3.5 Qes 0.42 Qts 0.40 Vas 85 liters Znom 4 Ohm Re 2.8 Ohms Le 1.3 mH BL 10.2 Sd 344 cm2 Xmax 18mm one way linear Pmax4 300W RMS, 600W peakNOTE: Power rating is thermal only! It is NOT a power requirement; typically you get full output with significantly less power than the rating. SPL 88 @ 1W, Diameter 10.5" Cutout 9.25" " Depth 4.75" Volume 0.08 cubic feet Weight 17 pounds
May 20, 200421 yr Looks pretty nice. Is it just a sq woofer or does it get pretty loud too? Good price for XBL^2. I bet that small looking motor will amaze you kind of like the tempest.
May 20, 200421 yr Author Primarily SQ in nature really, but it does do a bit better than a Shiva in similar alignments. That may not sound like much, but remember we are talking about a 10 inch versus a 12 inch woofer. All the motor is really in the topplate, not too much magnet on the driver. The depth is better suited to automotive applications, and I know Steve will be happy to see that .
May 21, 200421 yr Must add to the collection.................................Damn, I'm broke............... :thud:
