The revised E8 is on pre-order now! This is the last chance to get these direct at the discounted rate:
One Woofer - $65 shipped in the continental USA
Two Woofers - $125 shipped in the continental USA ($62.50 each)
Four Woofers - $240 shipped in the continental USA ($60.00 each)
Any quantity over four received the four woofer price.
Payments to be made via Paypal to [email protected]
The new version has the following changes:
1) Taller profile foam surround
2) Tied down tinsel leads, no possibility for slap
3) Stronger epoxy holding down spiders to basket
Pictures at the bottom of the post.
We upgraded anything that wasn't perfect on the first run :)
T/S Specs:
Re = 3.37 ohms (4 ohm nominal)
Fs = 34.9 hz
Qes = 0.5323
Qms = 6.93
Qts = 0.4943
Vas = 7.6 L
BL = 13.3 N/A
Mms = 127.7 grams
Cms = 162 um/N
Xmax = 12mm one-way linear (70% BL method)
Rated RMS Power = 200 watts
Depth = 4.25"
OD w/ gasket = 8 5/16"
Cut Out = 7"
Sealed Box:
0.280 ft^3 w/ F3 of 50 Hz (Qtc = 0.707)
Ported Box:
0.60 ft^3 tuned to 30 Hz
F3 of 25 Hz
SQ Review by "nismos14" on DIYMA:
Initially I was very impressed with the tonality and the output. It played various notes with authority. It's meant to be crossed (at least in my application) at 80 hz, anything higher and I recieved a lil breakup in the output. I am reallllly enjoying these subs with all kinds of music, rock/rap/country. They are doing a great job!
SQ: 8
Power handling: 9
LFE: 10
Output: 9
Build Quality: 10
Total: 46
These are just preliminary numbers, I will post more when I am done with a few weeks of listening time. They are DEFINATELY a competitor to the CMASS in overall sound and output! I am VERY impressed, especially at this price point.
* New taller surround / new style cone with slightly recessed dust cap
* Tied down tinsel leads - no slapping!
* Side view - same as before
* Rear view - same as before w/ pole vent and gap venting
  • Replies 107
  • Views 14.6k
Dang those look sexy. Are they 1.5" or 2" coil?
I don't know of a better 8" under $100 bucks.
Edited by Team Sundown Jerry
Sweet. I'm guessing they'll handle more around 400rms...... :neil:
Thermally they will handle alot - but they just don't need it. You can get them moving 1" p-p with the rated power in most enclosures.
Nice. I can't believe how much I like the high roll surround.
I foresee these selling like hotcakes.
The high roll surround really is dead sexy :)
After the preorders are done will they still be the same price?
Are they single 4 ohm?
No - they will be more expensive after the pre-sale. This is the last chance to get them at this price.
And yes, they are all single 4 ohm.
You dont have a price on them once the sale is over do you?
It will be around 100 dollars.
Awesome looking 8" moofaz!
Where can I find ts parameters for this thing? frequency range and rms power handling would be enough though. I wanna know how well this would work as a midbass driver in my front doors. Will it do well in a free air environment?
Full T/S specs are listed above - including the 200 RMS rating.
They will play up to ~200 Hz or so clean - so they will work as a midbass. We have two installed in a Bronco here for midbass and they do GREAT IB for that job :)
Nevermind, sorry, I kepy skipping right over the t/s specs without even realizing.
I can make them fit.... muahaha ;)
I might have to order a pair my door pannels need to be redone anyways. how dose an E8 and a multi sync 8 in each door sound?
How would 6 of these sealed in a regular cab S10 do on a 1500d??? I've had a DD 3510d ported and most recently a pair of DD 1508's ported also. Sorry Jacob, I'm kinda thinking out loud.
ALOHA FROM HAWAII,
SKY
Edited by hawaiianmaxx
ALOHA FROM HAWAII,
SKY
My Dad has two in a regular cab Chevy 1500 (ported) behind the seats and he does 137.2 dB with the windows down (131 windows up) - in a very good sounding setup :)
Whats the driver displacement???? i need to get 4 of these. whats the shiping to ALASKA (99517)???
i was thinking about getting 4 of these for my friend. 1000W/4 subs these would be perfect!!!
4Ft^3@30Hz wired parallel to 1 Ohm. sound good??????
Jason,
Shipping is an additional $35 per pair to your zip.
So add $70 to the price for four subs and thats it.
