I just want to know which is the better sub, i think i know the answer but would like some other ppl opinion. Thanks
Is there anyone else that as seen both subs in action and have an opinion on which is better?
SSD can be optioned up to your install. :)
SSD is much closer to the SX in terms of motor. SE is a decent drop in motor strength and a smaller OD.
SSD with flatwind is very similar to the SX. SSD with the copper coil is very akin to the older HC model in sound.
Thanks,
Scott
So which RE Audio sub would be compared to the FI Q Scott?
None really. The Q is somewhat similar in linearity to the older XXX, although distinctly different sounds between the sterile XBL enable XXX and the fuller sounding Q. Initially we had several people swap and do write ups on it.
Thanks,
Scott
Am just wanting to compares some subs here before i buy them. Can u let me know which Fi sub compares to the JL W6v2 and the W7 Scott? Am really wanting to out do a friend of mines. Thanks.
Edited by wof131s
I think the Q is the closest model to those.
so SEs arent a bad choice? i always see pairs or 15s on ebay for 300 all day i was going to get those or SSDs but thats closer to 500 bucks, i have 2 tma 1000 watt amps so 1000 to each sub on SEs will be loud?
i had a pair of 12 se's but want suming that i wouldnt wanna upgrade very soon. So i think i will go with 2 Q's in a ext. cab Dakota. Should be loud enough.
I know the SEs well, lol. They are a solid sub within their limits. The SSD is definitely more of a sub than the SE in all aspects, but for $300 a pair its hard to beat. Since I sold RE I know they moved SE production to China so I cant comment on the parts used now, but I do like the design ;)
Thanks,
Scott
  • 2 weeks later...
Listen, he has very extensive knowledge when your talking subs :)
so, ifi replaced my buddys se's with ssd's thre wont be much or a differnt, or would you even notice it?
yeah but my friend is asking to get louder and i was thinkking the ssd, but would it make a big enough differance to spend the money on them when he alrady has the se
Thanks,
Scott
It sounds like it would be like getting the SX from RE then.
iknow but i am just asking from expierance does anyone know if its work the money to change
would it be worht spending anouther 500 dollars the get the ssd's
If i were you, i would go with the SSD's. U wouldnt de dissapointed. If thats what u really want then get them, even if u have to save up to get them. BUT THATS JUST ME.
Edited by wof131s
the install is the most important part in a system so id look into doing a new box. from exsperience with an ex cab dakota they suck to get loud and peak is at 41 or 42hz its varied with boxes.
