Posted September 9, 200719 yr Just ordered 2 15" fully loaded BTL's. Wondering what to use for power as this will be mainly a SPL application. Using a wall in a extended cab pickup. Box area for subs will be close to 10.5 cubic feet after ports, subs and bracing are subtracted from total box area.
September 9, 200719 yr any amp that can do between 3-4000Wrms at either 1 or 0.5 ohmsooo......sundown saz3000d's.
September 12, 200719 yr Author Looks like I will be using a Memphis 4kw on each sub for now, hope to go to 2 4kw's each later. Also thinking of 16 volt charging system and several 16 volt batteries. Subs are dual 1 ohm. Edited September 12, 200719 yr by bdufner
September 12, 200719 yr for amps, im a rockford fan, i would go 2 t40001bd's. lotttsss of power and are .5 ohm stable for burps 3secs or less. each sub will see a lil over 5k watts that way! i think you will be impressed. the price is high but you damn sure get what you pay for!
September 13, 200719 yr Author I know what I can get the Memphis 4kw's for and they will run at 16.7 volts and 1/2 ohm. What will the Sundown SAZ-3000D's do and cost for the Sundown amps. Edited September 15, 200719 yr by bdufner
September 13, 200719 yr I know What will the what I can get the Memphis 4kw's for and they will run at 16.7 volts and 1/2 ohm. What will the Sundown SAZ-3000D's do and cost for the Sundown amps.http://www.soundsolutionsaudio.com/forum/i...?showtopic=9952That should answer your questions about the 3000D
September 14, 200719 yr Author Will these take 16 volts or what is the max voltage and the wattage at max voltage. Edited September 15, 200719 yr by bdufner
September 15, 200719 yr Author Subs came today send order on Sat. very fast and look great can't wait to try.
September 15, 200719 yr I'm pretty happy with the memphis 4k amps I have- but those RF birthsheets are almost all way over 4k. Just something to consider.
