Posted September 13, 200719 yr Hi i am considering getting a ssd 15 but am wondering if this amp,http://www.cadencestore.com/ProductCart/pc/viewPrd.asp?idcategory=125&idproduct=385 will push it enough to play some rock music. thx for your help
September 13, 200719 yr It would work yeah, but i highly suggest you look into getting a class D mono block amp...Or something that will do ~750-800 watts at 1, 2, or 4ohms.Thanks-Nick
September 13, 200719 yr Author It would work yeah, but i highly suggest you look into getting a class D mono block amp...Or something that will do ~750-800 watts at 1, 2, or 4ohms.Thanks-NickProblem is money, need to spend around that much on an amp, do you no anything about the pg octane 8.0:1 amp? Or maybe something better in the range of 150-200 Edited September 13, 200719 yr by trap08
September 13, 200719 yr Author It would work yeah, but i highly suggest you look into getting a class D mono block amp...Or something that will do ~750-800 watts at 1, 2, or 4ohms.Thanks-NickProblem is money, need to spend around that much on an amp, do you no anything about the pg octane 8.0:1 amp? Or maybe something better in the range of 150-200Or would the rf p150 25 to life be a better choice
September 13, 200719 yr It would work yeah, but i highly suggest you look into getting a class D mono block amp...Or something that will do ~750-800 watts at 1, 2, or 4ohms.Thanks-NickOr would the rf p150 25 to life be a better choice180 watts is nowhere near 750-800
September 13, 200719 yr Author its an under rated amp that puts out around 800watts though i just am not sure what sub the dual 1 or dual 2 to get with that amp
September 13, 200719 yr Author RF 500.1?no i thought the p150 has a birth sheet of around 800-900watts bridged power?
September 13, 200719 yr I think that amp is bridgeable at 4ohms...and by looking around a bit should do 900 watts or so...Might be a solid amp, i have no experience with it however.Thanks!-Nick
September 13, 200719 yr Author I think that amp is bridgeable at 4ohms...and by looking around a bit should do 900 watts or so...Might be a solid amp, i have no experience with it however.Thanks!-Nick so what impedence should i get the dual 1 or dual 2?
September 13, 200719 yr If it is bridgeable at 4ohms then you need to get a dual 2ohm sub and wire the coils in series for a 4ohm load.
September 13, 200719 yr Author If it is bridgeable at 4ohms then you need to get a dual 2ohm sub and wire the coils in series for a 4ohm load.Oh ok thanks, are the ssd ok to run at 1 ohm? if i were to get this amp instead since its a d class amp,http://www.cadencestore.com/ProductCart/pc/viewPrd.asp?idcategory=125&idproduct=380#details?thx you so much for the help
