Posted September 25, 200719 yr well just like it says which would I get the most output? By the way I would be useing one of the DP or BTL's or two of the mojo's. the box is approx. 11cf gross power will be atleast 4k. Out of the 3 choices I only have experience with the BTL (with cooling only)and am very pleased but would like more. If there is something else to consider then let me know also with an amp suggestion I have been leaning towards a stetsom. thanks mcbuggin Edited September 25, 200719 yr by mcbuggin
September 25, 200719 yr if the box is 11cubes then 1 btl would not be good too big. 2 would sound good in that size but ive heard that you can up the power on the fl btl so maybe you should try 2 4k amps and let it rip. maybe thats why you werent satisfied with the performance last time. and as for memphis im not goin to bad mouth them but i personally dont like them. they would probably blow with 4k. ive never heard of the other sub.
September 25, 200719 yr well just like it says which would I get the most output? By the way I would be useing one of the DP or BTL's and two of the mojo's. the box is approx. 11cf gross power will be atleast 4k. Out of the 3 choices I only have experience with the BTL (with cooling only)and am very pleased but would like more. If there is something else to consider then let me know also with an amp suggestion I have been leaning towards a stetsom. thanks mcbugginAre you saying you'll be running BTL's & Mojo's in THE same vehicle?Rephrase that or something, I can hardly understand what you're asking.. even after reading it many times.. lol.
September 25, 200719 yr oh yeah i guess i didnt read that right either. well you should never mix and match. that would sound like crap and never balance out. and the box would be way too small in that case (drop the mojo) add a btl
September 25, 200719 yr Author well let me say it a lil better. I would run 1 fully loaded BTL w/4-5k or1 DP 21 w/3-4k or 2 mojo 15 w/4khope this helps to clear the confusion. As for the box I said 11cf gross so before sub and port displacements. Also I love my BTL but it only has the cooling opt. for now and if I was to get another then it would be fully loaded. Edited September 25, 200719 yr by mcbuggin
September 25, 200719 yr Admin If this is going in a bug, a single large sub would be more impressive. Also we don't know the specs of the DP 21 yet.
September 25, 200719 yr I wouldn't recommend the mojos. They can get very loud, but I hear of people blowing them all the time when given more than rated power.
September 25, 200719 yr double post.I'd rather see 1 large sub as denim said. I'd try a different box if you aren unsatisfied with your btl before changing out equipment, that's me. Edited September 25, 200719 yr by tejcurrent
September 25, 200719 yr Author double post.I'd rather see 1 large sub as denim said. I'd try a different box if you aren unsatisfied with your btl before changing out equipment, that's me.I was thinking the 1 large sub also and the box will be getting changed. I am happy with the BTL but would like to get the fully loaded version as opposed to what I have. Imean if I'm going to buy a new sub it should be a infomed choice. That is why I am looking at the DP21 (hopefully get the specs soon) and I can get the mojo's for less than 600 new that is why I looked at those. thanks for the opinions keep them comeing. It looks like it'll end up being the fully loaded BTL or the DP21. now I'm not good with understanding all the specs so when they get them for the DP21 will someone please do a compairison with the BTL and get me a opinion.
