Posted September 27, 200718 yr What would be the power output of this amp at a steady 14.4volts at 1 ohm? And what battery would u recommend from powermaster?
September 27, 200718 yr Significantly more than rated. More important than the battery is how you have upgraded your wiring.
September 27, 200718 yr no idea on powermaster but im guessing u be getting around 1750 watts prob from 1 ohm at 14.4 if not more.
September 27, 200718 yr no idea on powermaster but im guessing u be getting around 1750 watts prob from 1 ohm at 14.4 if not more.Unlikely he'll get anywhere near that. It'll be over 1500w for sure, but under 1750w.Check out the power testing thread for the 1500D.http://www.soundsolutionsaudio.com/forum/i...?showtopic=7116
September 27, 200718 yr Not that this is disagreeing with you at all John, but if he could truly keep 14.4v at full current draw I bet he would. Good luck with that though.
September 27, 200718 yr no idea on powermaster but im guessing u be getting around 1750 watts prob from 1 ohm at 14.4 if not more.Unlikely he'll get anywhere near that. It'll be over 1500w for sure, but under 1750w.Check out the power testing thread for the 1500D.http://www.soundsolutionsaudio.com/forum/i...?showtopic=7116this link gives a better idea of what it does. http://www.soundsolutionsaudio.com/forum/i...?showtopic=7117granted that they are strapped.
September 28, 200718 yr Author my main question is im trying to figure out if one 1500 would push 2 fi q's or would they still be underpowered by alot
September 28, 200718 yr it won't be underpowering that much it will be around around 800 a peaice if you can maintain voltage in the 13's.
September 29, 200718 yr Two Qs on a 1500D will sound good.There are quite a few people running that specific setup. They seem happy.
