Monday I ordered 2 of the SAZ 1500d amps :domoslay::slayer::domoslay:
called Massive and told em i hope they did'ent plan on selling a lot of amps in Dallas or Ft Worth Tx
after Fu@king me around like that
a Happy Customer tells 12 people
an Un-Happy customer tells EVERYONE :werd_msword:
anyway after Much discussion with Djman, and James they agree with Jacob that the 2x 1500d's would be better in the long run over the 3000d for wireing options, as sometimes i use 2x 15" and the next time i will have 4x 15" subs !!!
I am so freekin Stoked :thanx:
Edited by Lord Baccus
Nice choice!
i am stoked for sure as i mentioned i have a friend that is running 1 SAZ 1500d on 2x SoundStream Splx subs and his 1st competition he took both
1st place for SPL in the Amature class & 1st place for SQ
he has been running the amp @ 0.5ohm dcr for a year now and has had no problems.... :domoslay:
i am a Diehard competitior and go out rain/shine/sleet or snow.... am looking forward to having amps that can deliver the push i need to keep people woundering how i breath in there when its so freeking Loud...
i am into Vision Blurrrrring
i did read the stickys over & over and i see it will do rated on lil or no power :) but how many batterys are needed to run both amps comfortablly ??
Depends on how you define comfortably :) Full blast output for like 30 - 45 minutes at a time? For a song or two?
for Dailly i roll about 1/2 volume
but for Burppppppping we use the TermLab so i think 4sec burst
Daily you would be fine with stock + one or two extra in the back no problem. If you can fit two, great, if not... one big one should work fine -- like a Powermaster D3100.
i have an 8v & a 6v battery that hold 14.97v @ a lil over 2000cca
i tie the negitive post to the positive of the other battery ( seires )
they will cook up to 19v but rest @ 14.97v
i use these too burppppp
and i have a strong stock setup that never dropps below 13.6v
130amp alt /
1x optima yellow / up front
2x batcap 800 near amp
