Posted December 27, 200718 yr I was just wonderin when the new production of saz 3000 will be in stock the end of jan or the beginning also is the heatsink gonna look different on them i thought i read that somewhere on here thanks for everyones time
December 27, 200718 yr i think jake changed the style if heatsink, but for the most part it will be tha same from what i understand the V1 and V2 are still stapable and all that good stuff, i know that jake will have some in his hands in jan, but i donno kno when there gonna be for sale,,, im lookin forwerd to it aswell
December 27, 200718 yr Author ok i was just tryin to get a time frame cause mine is already paid for was just tryin to get a time frame of when i need to get everything else ready for the new amp thanks for all the help
December 28, 200718 yr Yes and yes.I added a couple more fins on the side, there is a gap there now so I filled it in (minor detail, I know). Then the case is 10mm taller with a bunch of fins UNDER the face of the amp to drastically increase cooling. That is the primary change. The face of the amp is exactly the same.And yah, I expect them mid January.
December 28, 200718 yr Author Thanks i need to get to buildin the rest bats and alt and wiring thanks again
December 28, 200718 yr Author Hey also will a 200 amp alt and a hc2000 battery be enough for this amp
December 28, 200718 yr Hey also will a 200 amp alt and a hc2000 battery be enough for this ampI would prefer an HC2400 if you have only one battery.
