Just swapped out my US Amps for some Sundown Audio amps. Sad to see the ol' faithful US Amps go, this was VERY hard to do. I must be a responsible sundown dealer and use the stuff that I sell. I did consider slapping a sundown sticker on the US Amp heatsinks. :lildevil:
Old install
S8000190.jpg?
I still have an Fi Q12 and the Sundown SAZ-1500D is my first ever class D amp. I metered at 140.5 db. Pretty damned good if you ask me for the bass eating BMW trunk. A 2.3db gain since I was metered using the sub brand new with a super stiff suspension.
DSCF0437.jpg?t=1202482967
Measured by a termlab in the pass side kick panel. Peak freq was 47hz. The reading might be a little higher since I was inside.
Electrical:
Stock 120 amp alt
Kinetik HC2400 battery
Used 2007 db drag racintg 45 hz test tone
Gains were all the way down which didn't matter since I was overpowering the sub.
This Fi Q sub is a beast. I've been driving this sub with a 2000 watt amp and now a 1500 watt amp. The only thing that happens is I start smelling glue when the coil heats up. Takes it like a champ with a responsible user.
I didn't get a voltage reading since the sub was getting pretty hot. Sometime later maybe.
What amps are coming out and what amps are going in?
US Amps gone and Sundown is in. I figured that it would be obvious since I'm posting in the sundown forum. :P
As in the models you goof. :cookiemonster:
I see someone likes griots garage products
Ok..you got me.
Out:
USA-2000x
USA-400x
USA-200x
Fi Q12
(all of which are for sale)
In:
SAZ-1500D
SAX-100.4
AA Havoc 12
I would have shoehorned a 3000D in with another Havoc12 but I got so sick of installing 2 ft long US Amps with 4 power/gnd connection. I don't think I needed it anyways ;)
Edited by bigjae1976
Those amps should sell here.
Yeah, they make good stuff. Just gotta be careful with the wax...use too much and its like taking off dried peanut butter.
