this weekend i built a 3cf enclosure with 2x 4" areoports 7" long ea and did a 151.7db
lil Jeff showed up with a 12" Mtx and did a 141.8db then noticed the box was not sealing where the sub seats in the boxx
enuff blablabla
new Custom SD window decals.
mine
Jeffs
jeff using 1 amp
jeffs 12"
my single 15" boxx
2x 4" areoports
1st place & Highist Spl for the show :) 151.7db
Nice number, looks like you are starting to get more out of that explorer. :)
and the amps :)
Thank you i have allways wanted to break the 150db Barrier with a single sub :)
i beat a guy with 4 15" DD 9515's yesterday :slayer:
anyone digging the new SD decal ???
i took pics of the sun setting @ the lake & dropped it in as background for the cut text :domoslay:
Edited by Lord Baccus
Nice work!! Is your box in the position that you metered in?
Yes i have tried different positioning and subs forward / Ports up along the back window line yield the highist SPL !
if i lay the box on its back and fire the subs up & port to the rear i lose 2.3db
Congrats again!
i am out of flyers too pass out @ the shows ! everyone was asking about the amps agine :slayer:
Congrats again!
I'll have to send you some more :)
im supprised noone asked about the redickulesslly thick faceplate on the boxx 2.5" thick :slayer:
did not have time too FG Resin the inside of the boxx, or add 45 degree angles and tweek etc etc etc:
one of these days ill get too be on the sundown audio Team page :)
Everyone always assumes subs up, port rear is best in an SUV. Before my wall, my truck was loudest sub rearward, port out the side. . .
Brian
and the amps :)
That decal is pimp.
Jake needs to do a run of em. :cookiemonster:
and the amps :)
That decal is pimp.
all he has do do is call me i can get er Done :domoslay:
i need bigger SD amps & a Nightshade 15" !!!
Damn nice score!
Thank you Good Sir :)
i am testing an idea i had,
what i do is measure the distance from the sub too where the mic will be placed then convert the inchs into feet / times 4 / gives me the quarter wave # / i take that # and devide it into the speed of sound 1131 and get the Freq i need to port the box to :)
if i do it x2 i get the 1/2 wave and a lower tuning freq.... for street beet
then i look for a sub with an Fs of 34 or higher and Bammmmmmmmm
nice score man!!! you are motivating me to keep competing lol...and the sundown sticker looks tight!!
Thanks Guys
im all hard core SPL weekend warrior :domoslay:
if Jacob wants i can do a run of em and he can send em out with the amps like the one that came in the box ( white )
i can print anything then cut it for a decal
all 3m w/ 3m lam :slayer:
my work # 972*960*7200
SpeedPro Imaging
ask for Brian
Damn nice score!
what exactly do you mean if you do it x2 you get the 1\2wave? multiplying by 2 will double frequency result... do you divide in half?
In my case, it would be 25 hz, lol Some box i was testin the other sounded pretty loud between 30-33hz then got loud again at 39-42hz then hit the car's Fs at 49-54hz.
ok ill try this !
as an example...
if i measure from the placed sub/cone ---> to where the mic go's ( in the passenger Kick )
and i get 84" - translate that into FEET 7' -
take 7x4 ( 4 / quarter wave ) gives me 28
so i take 28 & devide that into the speed of sound ( 1131 ) equals = 40.39Hz
_________________________________________________________________
if i take that same 7x2=14 divided into the speed of sound ( 1131 ) = 80.78Hz
so with this theory if you want to tune lower go for the 1/8th wave
7x8=56 divide 56 into 1131 = 20.19Hz for a Sq Monster...
if im doing this wrong someone ( cough*M5///*cough) please feel free to step in and correct me :)
i've never really studied this, i've heard about it but never was really interested.
I take it -
1\4wave is for gettin loud, can also be used for SPL comp?
1\8wave is what you say, ultra SQ, hehe
what would 1\2wave be considered? the frequency will always be super high....
I take it -
in my 2000 Ford Explorer i have 2 Magic #'s 36Hz / & 54Hz
but the exception is when its HOT out side my # dropps too 52Hz ???!!!???
i do not know why this Happens ?
well that should be because everything expands if you apply heat...so that afects the lenght the wave has to travel and it affects the frequency....might not be right but thats how i understand it....
okkk i think my theory is right...say the 7' you used for yor example you add 1 inch or 2 so that ill give you 7.2x4=28.8
so that 1131/28.8=39.27hz....1 hz less than on you example
