Another option...
Continuing the current SAE-1000D board as an SAZ-1000D with accompanying upgrades to make it an SAZ class amp (and, of course, the SAZ case).
Then coming out with the SAE-800D model to fill in the SAE line at that power level.
That way the SAZ line has a smaller sub amp, people that want the small foot-print still get it, and I also have the less expensive model available for those that don't care about the size.
Good Idea.
  • Replies 63
  • Views 7.9k
Another option...
YES!!!!
Like the others have said, that is a great solution to the problem, would keep a very well rounded SAZ line, a well rounded SAE line and a good start with the NS line, I think it is the ideal solution to the problem.
Edited by bose301s
I like the idea because there are plenty of people who have an SAX-100.2 or 100.4 and want a matching mono amp, but don't need the brute force power or have the space for the 1500D.
Thats what I ran into, don't get me wrong, the SAE-1000D is an awesome amp, but I am not a huge fan of the looks, the SAZ and SAX lines are just so much sexier.
If I am understanding you correctly, the mono amp line up would shift to:
SAZ-1000D ~ SAZ-2000D ~ SAZ-3000D
??NS-4000D??
SAE-800D ~ SAE-1200D
If so, I think that would be a great idea!
Yep, thats the plan.
May even do an SAE-500D later on for the even lower powered crowd.
Would the new SAZ-1000D be strappable with the old SAE-1000D? I am assuming no since you would more than likely be changing transistors to make it a SAZ model and stable at .5 ohms, but figured I would ask.
Seems that this is a popular idea so far
I think you have found a winner!
Edited by bose301s
It actually would be since the basic board would be the same - one would just have to adjust the amp within the limits of the SAE amp connected.
Oh hell yea!! I am so for you doing this it isn't even funny!
Seems that this is a popular idea so far :)
I personally would shift to a combo of SAE-50.4 and SAE-800D, but I know the 50.4 is on the back burner, so the next logical option would be the SAX-100.4 and SAZ-1000D (and if it preformed like the 1500D, as in stability and power output and reliability, all the while having a small foot print) that would be a heck of a combo.
Side note: I was going to mention, if you had any totally fried SAX or SAZ series amps, I am sure, if you sawed the heat sink into 3 sections, people would buy them as a bridge like the old RF's. :)
I have some ideas for making link pieces sometime next year - perhaps even adding optional fan cooling channeled through the fins under the face of the amps.
??NS-4000D??
Just made a post pertaining about this before I saw this one
Could be interesting
