June 2, 200818 yr you need Dual 2s and get a maxxlink should make the strapping much easier especialy with 4 amps
June 2, 200818 yr not going to happen, you'll either need to give them half the potential power you have available (2 ohm) or run them at 1/2 with some beefy electricalor find some used 3000's or recone the BL's (or sell them and buy the correct ones)
June 2, 200818 yr Author you need Dual 2s and get a maxxlink should make the strapping much easier especialy with 4 ampsYeah thats what I was thinking. I might just wait on some 3000Ds then. Still have to start on the build anyways. Ill be looking for a low to mid 50s from this setup so im going to take my time and do it right.
June 2, 200818 yr when you strap, the lowest rated impedence doubles. So if you have two 1 ohm amps and strap them they become a single 2 ohm amp together.
June 2, 200818 yr Author when you strap, the lowest rated impedence doubles. So if you have two 1 ohm amps and strap them they become a single 2 ohm amp together.Got yeah. Thanx mayne!
June 2, 200818 yr I still think that 4 1500ds at .5 ohms will be louder than 2 3000ds at 1 ohm each... I have run strapped 1500d's at 1 ohm final load before (.5 ohms per amp) on a STOCK electrical system and Jacob's amps are solid.
