Posted June 26, 200818 yr Im looking for the Chaos sub specs, the website doesn't show them just the other models. Assassin, Arsenal, and Havoc.I have 2 1000 watt amps and was think of going either Chaos or Havoc.
June 26, 200818 yr Ascendant AudioC h a o s * Tough daily driving sub that has excellent SQ and output ability. * 10", 12", 15" and 18" Dual 2 Ohm models. * Double stack FEA optimized motor * 3" 4 layer aluminum coil * Triple layer reinforced collar * Triple progressive spiders * Ultra rigid reinforced cone body * Hybrid foam surround * Cast Alluminum basket * Wrap round rubber gasket * Silver 8AWG Push terminals * 800W RMSchaos 15 * Coils: Dual 2 Ohm * Re: 1.8 ohms * Sd: 810 cm * Xmax: 21mm (one-way) * RMS: 800WENCLOSURE -SEALED...1.5 - 3.0 CF-PORTED...3.0 - 5.0 CFits only that ?? Edited June 26, 200818 yr by SEBASTO
June 26, 200818 yr Author Ascendant AudioC h a o s * Tough daily driving sub that has excellent SQ and output ability. * 10", 12", 15" and 18" Dual 2 Ohm models. * Double stack FEA optimized motor * 3" 4 layer aluminum coil * Triple layer reinforced collar * Triple progressive spiders * Ultra rigid reinforced cone body * Hybrid foam surround * Cast Alluminum basket * Wrap round rubber gasket * Silver 8AWG Push terminals * 800W RMSchaos 15 * Coils: Dual 2 Ohm * Re: 1.8 ohms * Sd: 810 cm * Xmax: 21mm (one-way) * RMS: 800Wits only that ??Thanks for the info. I think Havocs are better for me.
June 26, 200818 yr Ascendant AudioC h a o s * Tough daily driving sub that has excellent SQ and output ability. * 10", 12", 15" and 18" Dual 2 Ohm models. * Double stack FEA optimized motor * 3" 4 layer aluminum coil * Triple layer reinforced collar * Triple progressive spiders * Ultra rigid reinforced cone body * Hybrid foam surround * Cast Alluminum basket * Wrap round rubber gasket * Silver 8AWG Push terminals * 800W RMSchaos 15 * Coils: Dual 2 Ohm * Re: 1.8 ohms * Sd: 810 cm * Xmax: 21mm (one-way) * RMS: 800Wits only that ??Thanks for the info. I think Havocs are better for me....good choice .... but u will need around 1.4kW for one ...
June 26, 200818 yr Actually i think those 1K watt amps should get the Havocs moving...What kind of 1K amps are they General
June 26, 200818 yr Author Actually i think those 1K watt amps should get the Havocs moving...What kind of 1K amps are they GeneralJL 1000/1
June 26, 200818 yr Author I wanted to go all JL but the 13w7's are just too damn much. Plus a shop down here is selling Havocs.
June 26, 200818 yr I wanted to go all JL but the 13w7's are just too damn much. Plus a shop down here is selling Havocs.for how much ??
June 26, 200818 yr Author I wanted to go all JL but the 13w7's are just too damn much. Plus a shop down here is selling Havocs.for how much ??I forgot but one of my friends works there and said he can get me a good deal on them. Im sure any price will beat what JL wants for a sub
June 26, 200818 yr From my experience with both... the JLw7 can get hella loud but all things being as equal as they could've been the havocs just sounded better and hellavuh lot lower... Let me clear that up a bit... It played the lower notes with better control then the JLw7... I would venture to say that the Havoc is a lot closer to JL's new w6.... The SQ is great on the havoc and it can get loud and low when it needs to...
June 26, 200818 yr We have had quite a few AA dealers that are JL authorized say the same thing. They are moving more and more of the Havocs than the JLs as they are just as clean, deeper, and handle more power... for less money. The look doesnt hurt things when selling them either.Thanks,ScottOh, and new AA site in the works to make the international distributors and US home look more uniform. Itll have the Chaos and Mayhem specs on it as well as some sneak pics of things to come for 2009
June 26, 200818 yr Author From my experience with both... the JLw7 can get hella loud but all things being as equal as they could've been the havocs just sounded better and hellavuh lot lower... Let me clear that up a bit... It played the lower notes with better control then the JLw7... I would venture to say that the Havoc is a lot closer to JL's new w6.... The SQ is great on the havoc and it can get loud and low when it needs to...Plus the weight was a factor. 50+ pounds for the 13w7 and mounting it was a pain. I know the Havocs get heavy but not that much.
June 26, 200818 yr We have had quite a few AA dealers that are JL authorized say the same thing. They are moving more and more of the Havocs than the JLs as they are just as clean, deeper, and handle more power... for less money. The look doesnt hurt things when selling them either.Thanks,ScottOh, and new AA site in the works to make the international distributors and US home look more uniform. Itll have the Chaos and Mayhem specs on it as well as some sneak pics of things to come for 2009 yea....folks say that the havocs r a jl copy ...in the terms of looks .....and what will be new ... HAVOC 22"
June 26, 200818 yr Admin We have had quite a few AA dealers that are JL authorized say the same thing. They are moving more and more of the Havocs than the JLs as they are just as clean, deeper, and handle more power... for less money. The look doesnt hurt things when selling them either.Thanks,ScottOh, and new AA site in the works to make the international distributors and US home look more uniform. Itll have the Chaos and Mayhem specs on it as well as some sneak pics of things to come for 2009 yea....folks say that the havocs r a jl copy ...in the terms of looks .....and what will be new ... HAVOC 22" Apparently they did not see the basket, motor structure, or T-yoke.
June 27, 200818 yr We have had quite a few AA dealers that are JL authorized say the same thing. They are moving more and more of the Havocs than the JLs as they are just as clean, deeper, and handle more power... for less money. The look doesnt hurt things when selling them either.Thanks,ScottOh, and new AA site in the works to make the international distributors and US home look more uniform. Itll have the Chaos and Mayhem specs on it as well as some sneak pics of things to come for 2009 yea....folks say that the havocs r a jl copy ...in the terms of looks .....and what will be new ... HAVOC 22" Apparently they did not see the basket, motor structure, or T-yoke. Or hear it Go Havoc FTW. I LOVE mine!!!BTW:here is a website w/ the info on all AA subshttp://www.bladeice.com/chaos.php Edited June 27, 200818 yr by nick_19
June 27, 200818 yr Author We have had quite a few AA dealers that are JL authorized say the same thing. They are moving more and more of the Havocs than the JLs as they are just as clean, deeper, and handle more power... for less money. The look doesnt hurt things when selling them either.Thanks,ScottOh, and new AA site in the works to make the international distributors and US home look more uniform. Itll have the Chaos and Mayhem specs on it as well as some sneak pics of things to come for 2009 yea....folks say that the havocs r a jl copy ...in the terms of looks .....and what will be new ... HAVOC 22" Apparently they did not see the basket, motor structure, or T-yoke. Or hear it Go Havoc FTW. I LOVE mine!!!BTW:here is a website w/ the info on all AA subshttp://www.bladeice.com/chaos.phpThanks for that site
