Posted July 6, 200818 yr I have a 12 Q D2 w/BP power. and just got a SAZ1500D.how much rms can a stock Q take daily. how about w/BP Power.i know Fi recommends 1000. just think it can take more. just want to see how much it can take to adjust the amp properly.
July 7, 200818 yr thermally the bp optioned should take the 1500 fine as long as it is clean but keep it a little lower just to be safe. mechanically depends on the box
July 10, 200818 yr Author thermally the bp optioned should take the 1500 fine as long as it is clean but keep it a little lower just to be safe. mechanically depends on the boxwhat do you mean by "mechanically depends on box"?
July 10, 200818 yr i believe nick said that a q without bp power can handle 1200 clean but anything more things start warming up id stick within recommendations at 1000, now with bp the 1500 is a perfect setup but just set your gains accordingly or you will fry things up.
July 10, 200818 yr thermally the bp optioned should take the 1500 fine as long as it is clean but keep it a little lower just to be safe. mechanically depends on the boxwhat do you mean by "mechanically depends on box"?A larger vented box reduces the power handling of the subwoofer. If I had a box that's the max recommended volume for a Q, I would send it 750rms....but that's just me being conservative...
July 10, 200818 yr Author so a larger ported box is like a sealed box, that they both need less power to push the sub,and pushing it any more will cause damage??
July 13, 200818 yr Gordon?Flash?G. Liddy?Naw, just a guy I know from the Maxima forum that uses carguyxxx in another forum. I quess it isn't him.
July 17, 200818 yr my q with bp power takes 1200 clean watts with joy off my hifonics 1608djust in case you were wondering.did i need bp power? probably not... but it was more of a user error protection for me lol
July 22, 200818 yr Ok wait i thought with sealed boxes you could give them a little more power than ported??
July 22, 200818 yr Ok wait i thought with sealed boxes you could give them a little more power than ported??depends on the size of the two. and tuning frequency. and frequency being played.
