which way should i go.
i have 16 mids for the MINI. all 8 ohm.
8 per door.
they will be wired in pairs of 4, in parallel, making each set of 4 mids a 2 ohm load.
so its either 2 100.2s, with 8 mids per amp (basically 1 amp per door) running each channel at 2 ohms
or 1 100.4, running 4 mids per channel, at 2 ohms.
the 100.2 is rated 200 x 2 @ 2 ohms
the 100.4 is rated 160 x 2 @ 2 ohms
i know the 100.2 is supposedly a little more underrated than the 100.4 is, but i found a good deal (IMO) on 2 100.2s, bnib for 370 shipped.
what do you guys think?
  • Admin
I voted 100.2's
I'd vote for more power as well. Especially if you have the space for the amps.
i would go with the 100.2s
also a 100.4 wont fit behind my seats there. they are 16.5" long i believe, and the new pre order 100.4s are going to be 1.5" longer on top of that. i only have about 16.5" TOTAL width, and the 100.2s are 13.375" long.
yea now that i think about it, since i cant fit the 100.4s behind my seats like the 100.2s will be, that means ill have 2 100.4s in the back, along with 2 3000ds. the 3000s take up 75% of the room, plus batteries, so no way im fitting more than 1 100.4 behind the wall.
100.2s it is.
The 100.2 is more power but the 100.4 has more control. How do you plan on crossing these over?
^^^^That is the question^^^^
for the time being, my pioneer 880 will be the xover.
when i put that back in my explorer, will be when i finish the CarPuter in the mini, and i can run a crossover and eq software.
Sweet! You gonna hook us up with some pics or what?
