Is it too early to get drunk?
Depends when you got up. I just woke up so i got my cup of coffee still.
Irish it up and you're good to go :)
:P
Last name is McNamara so i am fully irish
well I'm only half Irish so fill 'er up! :D
  • Replies 317.8k
  • Views 14.5m
  • j-roadtatts
    j-roadtatts
Random thought of the day....
Make weather seals on your doors hollow and sealed. Do some fancy magic to run an air hose to them and every time you close your door and start driving they fill up with air and expand to create a better seal and reduce wind noise....
Poast 270,000???
:morepower1:
Oh dear; did I actually make a thread?! :ohnoes9:
So I got my amp back installed, Turned on the music, closed my rear Extended Cab Door and the H701 just turned off and won't come back on :(
WTF ? That is ridiculous, sounds like you have some ground issues...
Did your amp fail, then got repaired and you didn't change the ground so it failed again?
Seems like I had a wee bit too much red wine and now I'm dizzy as hell.
What soludions do I have for tomorrow's possible headache ?
going to gurgle up 1/2 galon of water to keep me hifdrated and I'll read other solutios tomorrow after I wake up.
Everything out on the workbench, powered ftrom a battery. If there are problems with thge gear, they should be obvious there. If not, reinstall piece by piece and test.
RMS Power in Watts
@14.4V, 2O Mono, =1.5% THD+N 10000 x 1
@14.4V, 4O Mono, =1.5% THD+N 5000 x 1
Frequency Response, + 0 / - 1 dB -- 20 Hz - 200 Hz
90% efficient @ 2ohms
Signal-to-Noise Ratio -- >95 dB, a-weighted, re: rated power
Input Sensitivity -- 170 mV - 5 V low level
Low Pass Crossover -- Variable Low-Pass, 50 - 200Hz, 24dB per octave
High Pass Sub-Sonic Crossover -- Variable High Pass, 20 - 60Hz, 24dB per octave
Bass Boost -- Variable 0 to +18 dB boost @ 40 Hz
What you think guys?
RMS Power in Watts
Frequency Response, + 0 / - 1 dB 20 Hz - 200 Hz
I no buy without gut pics. And I onlt buy stuff I can fix myself, even in the extreme case I melt the board...
RMS Power in Watts
Found some test results on it
http://caraudiomag.com/articles/kicker-wx100001-warhorse-amplifier-review
Test Results
Output power @ 1% THD, 50Hz, 14.4 volts
Mono @ 4 ohms 1 x 5,494 watts
Mono @ 2 ohms 1 x 10,350 watts
Output power @ 1% THD, 50Hz, 12.5 volts
Mono @ 4 ohms 1 x 4,050 watts
Mono @ 2 ohms 1 x 8,052 watts
Distortion at rated power, 50Hz, 14.4 volts 0.66% @ 2 ohms
Input sensitivity 165mV to 5.2 volts
Frequency response (+1dB) 25Hz - 170Hz
S/N ratio (A weighted, below clipping, min. gain) >82dB
Idle current 3.5 amps
Maximum current consumption, unclipped 801 amps @
10,350 watts
Efficiency at one-third power, lowest impedance 88%
Efficiency at full power, 1%THD, lowest impedance 89.7%
Crossover slope 24dB/octave
Crossover range, lowpass 50Hz - 200Hz
Crossover range, highpass 20Hz - 60Hz
Low-frequency boost +18dB @ 40Hz
Dimensions 35"L x 17.75"W x 3.75"H
Weight 66.8 pounds
Holy shit that lightning was way way waaay too close
thunder clap sounded like a fucking deer rifle going off
sheeeeeeeeeeiiiiiiiiiiiiiiiiiitttttttttttttttt
Poast from the new phone :)
Sounds like your gun shy? :ughdunno:
*glances at .44 revolver, .22 rifles, and .22 pistol*
nope
aaand the turkey is in the brine
used disposable gloves, bleached the everloving shit out of the kitchen, and washed up to my elbows with soap and water for about a minute; if I get sick again it'll be a Christmas miracle
You'll probably get sick Peng! Lol
Well the H701 is getting power. The C701 is connected directly to it. The remote wire is reading .23V (DC). I'm not sure if that is what it is supposed to read but it still isn't powering up. I'm going to be sick if my H701 went out on me the day before I get my W505.
