I don't have a rear deck to mount to.
I'm thinking about sticking the extra battery in that cavity to the right of it. That's where the stock bass combo thingy majig was. Fiberglass a container in there, rivet in, mount the battery on it's side.
Then make a big amp rack.
The current picture looks pretty clean to me, which was the goal, but with the big enclosure sitting on top, it doesn't anymore. Not to mention if I ever change amps I have to redo the top panel.
If you guys have any favorite "clean" installs, post'em up. :D
Oh and my spare tire is underneath all that, so with the battery on side, a giant quick disconnect (8 speaker wires, 4 power wires, rem, and rca signal), and some gas lift supports, then I could actually use the spare if need be.
i cant quite judge the depth of your trunk so i cant tell if this would work.
i know this is a trunk install but it might give you an idea.
considering you have a large sub enclosure its hard to access amps and so forth without removing the enclosure.
this is what i worked out in my bro's car.
notice the false floor.
hinged panel gives access to amp w/o removing enclosure. i think if you did something with you false floor you would have room for more amps adjacent (to the left or right) to the amp pictured. i was constrained to the spare tire well.
after removing the enclosure the panel hinges again to give you access to the other amps.
wish i had pictures of this.. the whole amp rack pivots giving access to the spare.
  • Replies 317.8k
  • Views 12.8m
  • j-roadtatts
    j-roadtatts
So clean. :wub:
That is a pretty good idea to conserve trunk space. I've seen something similar before and thought it was clever too
DC650.6. :)
Doesn't look like a DC reference. Those have different terminals :P
Yup, it's a 1000.4 and a 500.1.
I should add that I would have never known that if I hadn't seen the original thread. :P
Beamer.
Actually I believe that is an older Mercedes.
Ill bet you its an x5.
Wait, I think your right. Lower right, you can barely tell the head light.
Beamer.
Only reason I know is I've seen the build log. :P
That's what I was thinking sort of, along those lines, thanks lithium.
There are subtle differences ;)
Too subtle for me to give a shit, then.
i have something similar, but it's just a raised floor, It's useful but I HATE adjusting my amps because theyre hard to get to
Roadmasters are fuckin' sweet. Nice find on the barely broken in '94.
Wasn't a hard find, it was my grandma's :P They bought it brand new. I actually have the original invoice. Very meticulous records kept on the car, every oil change/etc was logged in a notebook that she sent home with me as well.
Oh man, she must be a real peach. These things just float down the road.
So you got the RM huh Brad?
Yup, brought her home today. Took a while, didn't want to feel like I was swooping in on their stuff as soon as my grandpa passed away. But she called me about it last week, so I didn't feel as bad about it.
Nice pickup brad!
Dude, it's a car, not a pickup!
Unless you're talking about the GMC in the background, in which case, thanks. :P
