Saw a car on the way to work this morning that had its rear suspension so broken that the rear bumper was almost dragging on the ground & the wheel was bouncing up & down going down smooth pavement.
  • Replies 317.8k
  • Views 14.5m
  • j-roadtatts
    j-roadtatts
What do you guys think....
18" fi Q
or SDX 15.
it would be sealed. I have more than enough power for either with my saz1500....
I would have to really watch the gains with the sdx however.
I tend to steer away from XBL2.
Details ?
There are 2 SD-1 12"ers left, but that would then be in a sealed setup in her boat. Hmm, $80 isn't a lot of dough to try them.
I think they have a high Qts.
18" fi Q
or SDX 15.
Details ?
Personal preference and I guess some what comes with it. SSA will not have an XBL2 driver.
tempted by a pair of E8's for my boat though
Was just going to mention those.
:drink40:
18" fi Q
or SDX 15.
Details ?
How about just an under-hung, large excursion driver, something rather efficient like a pro-audio driver?
I said like a PA driver, not build me a PA driver... I'm an excursion fan. I wanted efficiency like a PA driver, it would be for a larger box, like 10 cubes for an 18" would be fine.
So you want a high efficiency, high excursion subwoofer??
High efficiency for excursion yes. It would be for home so box size really isn't an issue. I don't expect it to be as efficient as a PA driver, I was just looking for something that could move quite a bit without requiring a city blocks worth of power to move it.
Unless I was in a home that I owned with a crap ton of room I'd rather have a few big arse rack amps for the substage then have something the size of a Imp. Horn that I had to move around...
Let's put it this way, it would be more of a permanent room fixture, I have over 400sq feet of floor space and could easily fit a 30 cube box in my room without even noticing the missing space.
Lots of excursion isn't needed.
Build something like a Pass El-Pipe O and you won't be complaining the drivers don't have a lot of linear travel ;)
Sub only Imperial Horn.
'Nuff said. :D
What would a good home audio budget be...
Would 2500$ be enough for amps, a processor, etc... I don't really know much about home audio. I don't mind building my own stuff, I don't even mind building my own amps etc. I just figured if I am considering going to school for acoustical engineering I could get my hands wet with some home audio.
Are you want a 2ch setup or what?
2500 will get you some nice equipment.
2 channel, I would like to be able to cover the audible frequency plus some, well. So 12hz-24kz.
I will be building the room, my only major limitation is my low ceilings (6 feet).
