  • Replies 317.8k
  • Views 13.7m
  • j-roadtatts
    j-roadtatts
'Tis a whopping 333mhz and 265m ram I believe. So going to try old Suse 9.1 Pro on it.
256MB ram was a lot in those times :)
It is actually 2 old ran sticks I had sitting around. ;)
Going to the driving range. Gotta try to get my woods working, and maybe blow off a little steam. Yeah I know, it's probably not like shooting a gun.
I haven't made it to the driving rage yet. After the last time I played(Oct 6), I don't have any real ambition to play. I was duck hooking the ball and for someone that normally slices it, it was flustering.
I seemed to fix my problem yesterday! I realized that I was tucking my right elbow into or even inside of my hip on my swing. So I made the conscious effort to try and keep it out, and it worked wonders. Also trying to make my right arm do more work pushing the club because I tend to just pull the club through with my left arm, which not only kills distance but oftentimes opens the club face due to the dragging and causes a slice. But I found that this fix not only helped the straightness, but I also picked the ball up off of the ground a lot better. I've always had problems with just skimming the ball along the ground, but I got it into the air basically every time.
So point is, I think a lot of problems like these are a product of uneven force by both arms. That or rolling the wrists over too much (draw) or not at all (slice).
I will say the new f series are a bit transformer looking....
For some reason I like it though.
:fing34:
where do you aim while, hitting the ball? Do you aim to the inside of the ball?
*spit shines new avatar*
BURN YOUR BRAINS ON TEH CUTE!!!!!!!!!
i see nothing
all this talk of Stella made me go and buy a 6 pack of it....peer pressure is bad mkay.....
Went to Atmosphere last night GREAT FUCKING SHOW!!!!!!!
Go if you get the chance!!!!
How did the Hop end up on page 2? You guys are slipping. Back to the top.
I was out enjoying the wonderful weather today! Got the mower blade sharpened, the mower cleaned up, and the oil changed. I pressure washed the porch and hung out with Dad for the rest of the day. I'm poooooped.
Is your dad doing better?
Well my slicing problem was from an outside in swing pattern, which is easily correctable and had it pretty straightened out just the last time I played I got a hook going. I may have over corrected and started an inside out swing pattern, I don't know, there is only one way to find out where my swing is at and that is to hit the driving range.
reminiscent of Heineken to me...good stuff....
