  • Replies 317.8k
  • Views 12.9m
  • j-roadtatts
    j-roadtatts
so yeah, putting down the second layer of plywood on the den floor this weekend...should be interesting...
Low lie the Fields of Athenry
Where once we watched the small free birds fly
Our love was on the wing we had dreams and songs to sing
It's so lonely 'round the Fields of Athenry
my dad: "find out the right way to put in these windows (in the den)"
me: "you mean we put the other six (that we've already installed) in wrong?"
:tehe:
time for my last pre-major lower division final ever! goodbye SBCC! hello UCSB!
:D :D :D
I have 2...both are dumb as rocks though...matter of fact I think one of them is chewing on a rock right now....*peers out the window*
Well I met an old friend yesterday, and I also learned that my ex has been telling people I stalk her.
Edited by patented17
Time for 2 mile jog, god I hate running...
ah, thought it was a stereotype I didn't know about
definitely a stereotype you didn't know about, kayakers and snowboarders are both notorious stoners. Though i'm not sure i'd like to try kayaking high, maybe the relaxed flatwater kayaking, but whitewater is too intense and i'm not good enough yet.
grr, I was hoping to run a return-less fuel system on the 'maro, but after some reading, it seems that with-return-line is the way to go
Return style FTMFW! I could kill Ford for this. Seriously. You want to talk about gas hog and harder to tune.
so return style really is that much better? even for just a carb?
I don't know that I'd bother with it in that instance. All your tuning will be done at the carb, and it's low pressure, so I don't see a need for a return line. If it's too rich, change the jets or vice versa.
returnless would be much easier...
but one thing I'm concerned about is since I'm using an electric pump, it's going all out all the time while a mechanical's flow is rpm dependent, would there be problems with it sitting at idle or even with just the key on?
It's just like a water pipe. You have the pressure at the valve at all times, but volume will be controlled by the valve. The engine will only use what it needs.
is that rough on the pump though?
No, all electric pumps operate this way. You just don't have the benefit of a computer controlling the voltage to regulate flow and pressure as precisely. Of course you won't need to worry about this either with low pressure.
cool, thanks :fing34:
The Twin Cities blasted into a heat record Tuesday with a high temperature of 97 degrees, breaking the previous record for the date by eight degrees.
Meanwhile, as Granite Falls hit 100 degrees at 5 p.m., Grand Marais was recording 34 degrees, giving Minnesota both some of the nation
for you pic whores, still need to put the F-body oil pan on
Sexy powerplant pron. What will it put out?
it was rated at 295/335 in the suburban it came out of
so that without AC and PS pumps, without restrictive exhaust, and with the slightly larger cam
I don't think 300 at the wheels is out of the question
^ thats great
implied for pengs post
you can do that anywhere there's a water spigot
definitely going to play Walmart Bingo sometime
ya sounds like a good time lol
probably be easier to get that one done in my home town, instead of beaumont
Off to the gym. :)
quote from one of my black friends
on the theme of dunking balls lol
"have you guys every dunked your balls in the toilet while you were taking a shit?"
i was pretty much like WTF
