Posted October 20, 200817 yr I went to Sicnick Yesterday / Pulled into the lane and burped a 151.5db 2x 15" Pap Wmd^2 subs 2x Sundown SAZ 3000z amps 1 MLA controller boxx laying down / subs up^^ ports back<< / Under the window line / using the G@y@ss Hampsterball-mic holder Voltage never dropped below 14.7 took 1st place in my class / 600-1800stock beat a a lot of guys with more subs etc etc etc i lent the LB MOAB XxX to my Friend Trevor / he took 1st place also 0-600 with a 143.4db / using a lil Memphis 1000d amp and only the stock Battery & alt
October 21, 200817 yr Author Thank you the boxx position was not the way i normally meter / with the boxx layed down / subs up / ports back i lose 3db off the top / but it was my only option as i scouted the competition and / Stock 600-1800 was my best chance of a fare competition as the others in Mod had the addvantage !!! i did testing earller that morning and with the box in the normal position i was doing a 151.7db on the Glass & a 152.7db in the kick... without getting on it full tilt
October 21, 200817 yr Thank you the boxx position was not the way i normally meter / with the boxx layed down / subs up / ports back i lose 3db off the top / but it was my only option as i scouted the competition and / Stock 600-1800 was my best chance of a fare competition as the others in Mod had the addvantage !!!changing the position of you box changed the class you ran in?
October 21, 200817 yr Box has to be behind b pillar and below windowline or he will be considered modified (wall/16volt class)Been competing in Usaci for 3 years now so i know the rules a bit Edited October 21, 200817 yr by Duaber
October 21, 200817 yr Box has to be behind b pillar and below windowline or he will be considered modified (wall/16volt class)Been competing in Usaci for 3 years now so i know the rules a bit oh, ive just done a few local comps with classes based on sq in of subs and extra batteries Edited October 21, 200817 yr by fritosaregood
October 24, 200817 yr Author Thanks Guys it was my 1st Usaci Competition in over 8 yrs...i have to addmitt that a lot of there rules are designed to keep you from getting loudseems like the Usaci is over burdened with too many UNnessary rules.They count the sweep as part of your time on the mic & only give 26sec for a burp ???WEAK /// too say the Least i was NOT impressed @ how they run their shows...and that Hampster Ball on the mic was G@Y...Just my .02cents No where Neer as fun as a Texas Bass Productions event
October 24, 200817 yr The "hamster" ball makes it easier to shove in the kick and protects the sensor at the same time. BTW any serious competitor should read over the rules of an organization and I believe you were in the wrong class since you aren't 12v (At least im assuming that since in your posts u were trying to get close to 18v) Just looking out for you so you don't get called a cheater or get disqualified. But enjoy your first place I know how good it feels If anybody has any questions about usaci give me a pm. If you want to have some fun you should try streetbeat I do it and I have a blast! Basically you gotta play music (can't be burned) for 30 secs and they take the average of your score(Electrical system is important to maintain score)
October 25, 200817 yr Author The "hamster" ball makes it easier to shove in the kick and protects the sensor at the same time. BTW any serious competitor should read over the rules of an organization and I believe you were in the wrong class since you aren't 12v (At least im assuming that since in your posts u were trying to get close to 18v) Just looking out for you so you don't get called a cheater or get disqualified. But enjoy your first place I know how good it feels If anybody has any questions about usaci give me a pm. If you want to have some fun you should try streetbeat I do it and I have a blast! Basically you gotta play music (can't be burned) for 30 secs and they take the average of your score(Electrical system is important to maintain score)im nowhere neer 18v... thats next yrs setup...after i drove to the show and the batterys are charged i was ideling @ 14.7v which is LEGAL in Usaci...i am going to have a DIFFERENT module built that will allow me to switch to 17.9v but as for now im Usaci Clean/// not Cheeting on anything...I did TRY to read the Usaci Rules but i need a LAWER to Translate the d@mm thing
October 25, 200817 yr Author the mic stand dosent affect your score so quite your bitchinNot complaining just pointing out that there show is over burdened with rules...i did compete in there show and WON without breaking ANY of THEIR RULES where does that come off as bitching Bro Coffee comes in DECAFF
October 25, 200817 yr I went to Sicnick Yesterday / Pulled into the lane and burped a 151.5db 2x 15" Pap Wmd^2 subs 2x Sundown SAZ 3000z amps 1 MLA controller boxx laying down / subs up^^ ports back<< / Under the window line / using the G@y@ss Hampsterball-mic holder Voltage never dropped below 14.7 took 1st place in my class / 600-1800stockhow did you not drop below 14.7? I got a 300amp alt, yellowtop under hood and 3 Powermaster D3100s in the back by the amps and at full tilt i still drop to around 12V
October 25, 200817 yr Haha I hear that about rulebooks everyones seems different. I'd love to tryout the MECA format with the headrest stand but they just aren't around my area.PS Sorry baccus and team sundown didn't mean this for to be a blame fest like stated just want the team to look good by following the rules Edited October 25, 200817 yr by Duaber
October 25, 200817 yr Haha I hear that about rulebooks everyones seems different. I'd love to tryout the MECA format with the headrest stand but they just aren't around my area.PS Sorry baccus and team sundown didn't mean this for to be a blame fest like stated just want the team to look good by following the rules Ive got one thing against MECA to be compedative you have to run a bunch of small fuses which can get expensive quick especially in testing
October 25, 200817 yr Author I went to Sicnick Yesterday / Pulled into the lane and burped a 151.5db 2x 15" Pap Wmd^2 subs 2x Sundown SAZ 3000z amps 1 MLA controller boxx laying down / subs up^^ ports back<< / Under the window line / using the G@y@ss Hampsterball-mic holder Voltage never dropped below 14.7 took 1st place in my class / 600-1800stockhow did you not drop below 14.7? I got a 300amp alt, yellowtop under hood and 3 Powermaster D3100s in the back by the amps and at full tilt i still drop to around 12VMLA Rules... i haVE a Stock ALT with an Optima Yellow in the stock battery position and 2x Northstar NSB 125 & 90 under the amp rack the MLA controler adjusts the curve on the thingamajigg (alt) that keeps me hummmmmming at FULL power, but latelly iv been thinking i need some dilythum crystals so i can go too warp 6 read: http://www.missinglinkaudio.com/id27.html
